04-12-2018, 12:40 PM
Low point drains
The low point drains on our 8289WS were simply PEX tubing with threaded caps on the end. Removing the caps to drain the system tended to get me wet. I found these valves on Amazon: https://www.amazon.com/Zurn-Pex-Poly.../dp/B0080KI7RU . They simply screw on in place of the caps, no tools needed. (Thanks to Kamper00 for the idea.)
04-12-2018, 08:17 PM
Good idea!
2018 Flagstaff 25FKS
2015 Ram 1500
04-12-2018, 09:24 PM
thanks for the idea I just ordered two.
Retired Navy
2016 Flagstaff 26 FKWS
04-14-2018, 08:52 PM
id do the same thing but the shipping is a bit too expensive!
https://www.amazon.ca/Zurn-Pex-Polym.../dp/B0080KI7RU
2023 Rockwood 2911BS | 2023 Silverado 3500 SRW Duramax
04-14-2018, 09:41 PM
Free shipping today. Thanks for the idea.
Buzz & Jo Wolf
5er: 2018 Cedar Creek 29ik
TV: 2014 F350 Diesel
04-15-2018, 07:05 AM
Go to any Ace/Lowes/or HD......1/2 ball valves are cheap.
04-15-2018, 07:36 AM
I bought two PVC ball valves at Lowe's for $3 each but they are so hard to turn I am afraid the PEX will kink before the valve turns. May be a two handed operation.
04-15-2018, 07:38 AM
But those are brass. Much heavier. Was concerned about that weight hanging loose at the end of the PEX.
04-15-2018, 07:55 AM
When I did mine a couple years ago I also added anipple with hose barb and a short length of tubing to jeep the road dirt out of the valve
04-15-2018, 08:18 AM
Retired Navy
I ordered two with free shipping. Thanks...
2012 Lexington C Class
Toad: 2009 Honda Fit
04-15-2018, 10:18 AM
$3 at Home Depot and does the same thing. Have done it on my last two campers.
04-17-2018, 12:25 PM
I added short hoses and quick connect to my low Point drains and purchased the plastic folding table from Amazon with a built-in sink I now have a portable sink outside with hot and cold running water I just use a 5 gallon bucket underneath for the drain
04-17-2018, 03:43 PM
Great idea!
2017 Rockwood Ultra V 2618VS
2017 GMC Sierra 1500 SLT Crew Cab Z71, 5.3 EcoTec V8
Nights Camped: 10 (so far) in 2024; 28 in 2023
04-17-2018, 03:50 PM
Here's mine...
04-17-2018, 04:24 PM
Originally Posted by 5picker
Here's mine...
What are those called and where did you get them??? They look sooooo much smaller and less clunky than the valves I’ve seen around!
Need! [emoji16]
Carmen and the pack
2015 Coachmen Clipper 17BH
2017 Dodge Durango Citadel 5.7 Hemi
04-19-2018, 09:03 AM
Need! [emoji16]
Sorry I just seen this...
They are ball valves made by SMC.
I like them because they are full port and do not restrict flow which helps when draining, winterizing and just overall general use.
A garden hose attaches easily for any number of uses.
Once, some friends we were boondocking with ran out of water. I hooked a garden hose to one of these and easily pumped 10 gallons from my tank to theirs. Got them through the weekend.
I purchased mine through McMaster-Carr and I've seen them on eBay and other places.
You can find them here...
Light Grey PVC On-Off Valve
eBay Link To SMC Ball Valve
04-19-2018, 10:03 PM
Thanks!
Carmen and the pack
04-19-2018, 10:22 PM
this is what I used, they come in red and blue, ... mine are right behind one of the rear tires, to keep them clean from road grime, dirt, sand, ect, ..., I crimp a piece of aluminum foil down around them, ... does a good job of keeping them clean, and cheap to replace with a new piece after draining the lines for winterizing, ....
https://www.amazon.com/Ecopoly-29891...19GVD1BNSX0ERR
04-19-2018, 10:32 PM
5picker... did you have to use an adapter to go up to 3/4"?
You can avoid reality, but you cannot avoid the consequences of avoiding reality – Ayn Rand
04-19-2018, 10:52 PM
Excellent idea but we camp below freezing frequently in the winter.
"*Temp. Range: 33 Degrees to 200 Degrees F*"
I put these on and they are very easy (vs brass ones)
BestPEX 51249 Metal Chrome 1/4 Turn Straight Valve, 0.5" Size https://www.amazon.com/dp/B002Z9B6U2..._xow2AbX0A0BV8
2016 RAM 3500 DRW 4x4 LB LoneStar, w/RDS 33Gal Aux tank, Timbrens, Andersen Ultimate2, SwiftHitch SH04
2018 Chaparral 360IBL w/TST507 TPMS, Lippert GC3 Autolevel, Furrion Backup Cam, Progressive HW50C
2006 RAM 3500 DRW LoneStar Edition
2011 Starcraft 392BHUw/Andersen No-Sway
