Old 10-23-2014, 09:05 PM   #1
Manual Slide Operation - 8285WS
I searched for a bit on how to manually operated the large slide and could find nothing. So I finally found out the place where the manual shaft is located.
It is on the side opposite the slide, between the the two tires and high up in the wheel well. It is a shaft with a thru-pin - It uses the same crank as the one for manual operation of the landing gear. However on mine the outer fender trim will not allow you to install the crank - I cut a 1" hole in plastic outer fender to allow a straight shot at the shaft.
cadman99 is offline   Reply With Quote
Old 10-23-2014, 09:16 PM   #2
Ret E-9 Anchor-clanker
donanddona's Avatar
Well deserving of a posted picture. Need a part time job?
donanddona is offline   Reply With Quote
Old 10-29-2014, 06:16 PM   #3
Okay - here's a pic
Old 10-29-2014, 06:34 PM   #4
Herk7769's Avatar
Mine actually had the hole from the factory.
Name:	9 Nov 2009 001.jpg
ID:	65558   Click image for larger version
Name:	9 Nov 2009 003.jpg
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
Old 10-30-2014, 07:09 AM   #5
sonic2's Avatar
Lippert Video and Manual for slide out operation
http://lci1.com/images/support/manua...ideout-web.pdf
Here is a link to a video and the manual for electric and manual slide out operation.
2014 Rockwood 8289WS - Goodyear Tires
2022 F350 King Ranch Crew Cab
4x4 - 7.3L - 3.73 - 6 1/2 bed - Michilien Tires
Timbren & Anderson Ultimate 5th Wheel Hitch
sonic2 is offline   Reply With Quote
manual, slide
