02-12-2019, 09:26 AM
Manual slide out
Hi I have a 2015 8280WS ultra light, I was wondering how you manually retract the slide, I have a handle but I can't find anything to connect it to, I am in the UK no dealerships here, I would be grateful for any advice.
02-12-2019, 09:33 AM
Many times the place to attach the manual crank for a slide is on the opposite side of the R/V from slide you are trying to move. Also the procedure is different for different types of slides. Do you know what type you have?
02-12-2019, 10:15 AM
Mine appears to be a gear that runs a toothed bar in and out, if that makes any sense.
02-12-2019, 10:24 AM
You may have a Schwintek slide.
2011 Traverse LT, 3.6L, FWD
02-12-2019, 10:29 AM
No it's definitely not like that, I will try and photo it.
02-12-2019, 10:37 AM
Ok this is the mechanism.
02-12-2019, 12:44 PM
That's a thru-frame slide, and it operates like the video 5Picker posted.
Gotta go campin!
02-12-2019, 12:52 PM
But, unlike the video, there is nowhere to attach the handle to wind it in?
02-12-2019, 01:02 PM
On our unit, you have to crawl under the RV to operate the slide manually. There's no hole from the factory through the skirting. I have a cordless drill and adapter made, but I hope I never have to use it.
Gotta go campin!
02-12-2019, 01:16 PM
Just as confused as you
If you have 2 slides opposite of each other you will have to do as Bama Rambler said.
If it is a single slide there will be a 1-1/4 inch (31mm) hole in the skirting (great for mice getting in) on the opposite side of the trailer. My slides have the same mechanism. See pages 16 & 17 of the attached manual.
Richard & Jill
02-12-2019, 01:19 PM
If it is a single slide there will be a 1-1/4 inch (31mm) hole in the skirting on the opposite side of the trailer. My slides have the same mechanism. See pages 16 & 17 of the attached manual.
Hi, thanks but there is no hole in the skirt and nowhere to attach the handle, that's the problem.
02-12-2019, 01:26 PM
Referencing the picture you posted, On the opposite end of the pinion shaft and down between the frame rails is the motor and gearbox. You'll find the pin for the manual crank there. It may be hard to see, but it's there.
Gotta go campin!
02-12-2019, 02:15 PM
Thanks for your help, dark here now, I will look there in the morning, grateful for your help.
02-13-2019, 06:03 AM
Hi ok I have taken two shots of the other end of the shaft, can't see anything there either except a hole in the end of the shaft??
02-13-2019, 07:29 AM
There should be a motor there, it is shaped like an egg, about the size of a large grapefruit. You will find a 3/8ths to 1/2 inch rod coming out of it. On that rod is an almost cotter key looking thing going through it that the handle goes in, then you start turning.
2018 Flagstaff 832IKBS Travel Trailer.
2015 Silverado High Country.
02-13-2019, 07:44 AM
That is the mechanism that keeps the slide straight. If it is a electric slide the motor unit is usually between the frame and it drives a rod attached to the slide. If it is hydraulic it has a pump that drives it similar to the electric except it is a hydraulic cylinder.
2001 Ford F-350 DRW 7.3
2011 25 RL Wildcat
former fiver 1976 Fourwinds had for 35 years
02-13-2019, 08:03 AM
Here's what yours should look like.
Gotta go campin!
02-13-2019, 04:08 PM
Yes I believe that is my setup, thank you.
02-13-2019, 04:37 PM
Again... the place to put the manual crank is likely on the opposite side from the slide out. It may/may not have a hole in the bottom skirting. There may just be a hole in the frame rail.
If you look at the photo Bama posted you will see the extension rod attaches to the back side of the motor and is pointing away from the moving part of the slide. Where you attach the crank is nowhere near the rack parts that are in your photos.
02-15-2019, 02:18 AM
Ok thanks, I will keep looking, it must be there somewhere!!
