Old 05-16-2022, 08:40 PM   #1
Casual Camper
Marker Lights Not Working
As stated in title. Marker lights are not working. Left and right turn signals and brake lights work as expected, electric brakes work as expected. Checked pins on trailer and truck side with multimeter, everything seems okay on both sides. They were all working last fall, now not working, ALL marker lights.
Also reviewed this thread
Looking for more troubleshooting ideas.
Daniel and Judy
Camping Dog - Ace
TV - 2020 Chevy Silverado
RV - 2021 Rockwood 2608BS
Ex-tenter is offline   Reply With Quote
Old 05-16-2022, 09:13 PM   #2
Casual Camper
Reviewed the thread again and re-checked the pins on the TT side. If I short the correct pins, all of the marker lights come on.
So, the lights are functional, but the TV for some reason is not providing the appropriate signal/voltage to make it happen. It's dark out now, I'll take another stab at it tomorrow, but any suggestions are welcome.
Daniel and Judy
Camping Dog - Ace
Old 05-17-2022, 08:20 AM   #3
grege's Avatar
Have you checked to see if any fuses on your truck blew?
'18 Ford F250 Lariat Super Crew
'22 Rockwood 2608BS
Previous '17 Grand Design Imagine 2800BH, '13 Rockwood Roo 21SS
grege is offline   Reply With Quote
Old 05-17-2022, 05:37 PM   #4
Casual Camper
Yes, I checked continuity on every fuse that had indications of being involved with the trailer. As my truck's brakes and lights all seem to be functioning, I'm assuming it's not the normal lights fuses.
Daniel and Judy
Camping Dog - Ace
Old 05-17-2022, 06:34 PM   #5
Mr. Dan's Avatar
In a truck as new as yours, fuses for trailer functions are not the same as for the truck... may not even be in the same fuse panel.
Nights Camped: '13 = 49/'14 = 74/'15 = 74/'16 = 85/'17 = 110/'18 = 111/'19 = 86/'20 =108/'21 = 115/'22 = 68; Booked for 2022 = 41
Old 05-17-2022, 06:41 PM   #6
Casual Camper
Oh, sure. But I took the cover off the panel and it has a nice chart on the inside that shows all of the fuses and clearly labels which ones have what functions. There are a number of them specifically labeled for trailer functions. It's possible there's another fuse block hiding somewhere, but I have not been able to locate one, and I think it would be odd of Chevy to put some in this box, and some in another box. Not saying they didn't, just saying IMO it would be dumb. I'll have another look for another fuse block somewhere.
Daniel and Judy
Camping Dog - Ace
Old 05-17-2022, 06:59 PM   #7
clr
It sounds like you have lost the ground connection for the marker lights. TT tend to use the metal of the unit as a ground return. So one wire to the marker lights is hot or 12vdc and the other connects to the metal of the TT. I would check the hot wire with a multimeter and insure that you have the 12vdc when the lights should be on. If you have power you will have to either correct the poor connection to the light or provide a new ground path for the light.
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
2015 Prime Time Sanibel 3601
clr is online now   Reply With Quote
Old 05-18-2022, 05:02 AM   #8
What do you mean "if I short the correct pins"? Use a multi-meter (or a test light) to check that you are getting power from the tow vehicle. Look online for information about which prongs supply ground and hot for marker lights. Check under the back of the truck to see if a wire pulled loose or has rubbed. Pull the fuse in your vehicle and check for continuity. Sometimes they blow and it isn't easy to see. Clean the connections with a wire brush. Let us know what you find.
mnoland30 is offline   Reply With Quote
Old 05-18-2022, 08:16 AM   #9
THREE panels
There are THREE fuse panels on a 2020 Silverado.
  1. Under the hood
  2. At the left end of the dashboard (open the driver's door and pull off the end of the dash)
  3. At the right end of the dashboard (open the passenger's door and pull off the end of the dash)
If you RTFM (Read The Fine Manual), you will see the instructions and even be able to identify which panel has the trailer fuses. (I'm betting driver's side.)
Larry
Larry-NC is offline   Reply With Quote
Old 05-18-2022, 08:18 AM   #10
Nope!
Nope. The OP stated that when he jumpers +12 to the marker lights contact on the umbilical (11 o'clock to 1 o'clock) the lights come on. That establishes that the ground connection is okay.
Larry
Old 05-18-2022, 08:53 AM   #11
What I have experienced on my truck when hooked to my cattle trailer (same type of plug as RV), is that the blades in the plug eventually get squeezed together from repeated use so that they don't make good contact with the trailer. So I use a pick and screwdriver to spread both sides a little, and at the same time polish them up a little best I can. I've gotten things working again doing this occasionally.
Dave in SK
VE5DLC
Trailer: 2011 Cedar Creek Silverback 35K
Truck: 2006 Dodge 2500 TRX4 Cummins
Seasonal at Saskatchewan Landing Provincial Park
camaro80 is offline   Reply With Quote
Old 05-18-2022, 10:37 AM   #12
TGR
TGR's Avatar
Check the tow vehicle's wiring at the 7-pin connector with a multimeter or DC circuit tester. The running lights are on pin 3 and the ground is on pin 1.
To easily check the trailer's running lights, bridge pins 3 and 4 on the trailer's connector with a 10 or 15-amp fuse. The blades of the fuse will plug into your trailer's 7-pin connector with a little fussing. Your trailer's battery will now light the running lights. Of course, you need to ensure the trailer's battery is connected and supplying power to the trailer.
ID:	273476   Click image for larger version
2015 Wildcat 282 RKX
2011 F350 Lariat, 6.7 L. Diesel, 8 ft., SRW, Reese R20
TGR is offline   Reply With Quote
Old 05-18-2022, 06:23 PM   #13
Casual Camper
I can see this being a thing, but my 2020 Chevy has only pulled this trailer less than 1000 miles, so I don't think it's the case for me. I'll look, but I'm not optimistic this is my answer.
Daniel and Judy
Camping Dog - Ace
Old 05-18-2022, 06:25 PM   #14
Casual Camper
To further confirm this, I purchased one of these:
https://smile.amazon.com/Camper-LITE...ps%2C89&sr=8-2
Connecting it to the trailer, the lights all come on. This pretty much mandates that the trouble is on the truck side.
Daniel and Judy
Camping Dog - Ace
Old 05-18-2022, 06:27 PM   #15
Casual Camper
I've done this; when connected in this way, the marker lights all come on. So the trailer side appears to be functioning correctly, the problem is almost certainly on the truck side.
Daniel and Judy
Camping Dog - Ace
Old 05-18-2022, 06:29 PM   #16
Casual Camper
  1. Under the hood
I've gone through the under-hood block entirely. I'll check the others after supper. Thanks for the pointer!
Daniel and Judy
Camping Dog - Ace
Old 05-18-2022, 06:43 PM   #17
Casual Camper
  1. Under the hood
So, you're correct about the fuse blocks on either end of the dash. Looking at both of those, only one spot is marked for anything to do with a trailer (Euro TRLR) and that location is not used. I am not hopeful these locations will be useful, but I will test all of the fuses with a multimeter. Most seemed to be indicated as relating to the interior comfort features - power seats, heating, etc.
Daniel and Judy
Camping Dog - Ace
Old 05-18-2022, 07:01 PM   #18
SailorSam20500's Avatar
I think on my Ford, I have to have the headlights or parking lights on to get the marker lights powered... I know one or the other need to be on to get my backup cam to work...
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
SailorSam20500 is offline   Reply With Quote
Old 05-18-2022, 07:19 PM   #19
clr
You say the turn light work properly. Does that also mean that the tail lights work when the truck lights are on?
Chuck & Sandra
Engineer/Teacher
2010 F350 CC 6.4
Old 05-18-2022, 08:14 PM   #20
Casual Camper
No. I only get turn signals and brakes.
Daniel and Judy
Camping Dog - Ace
light
