Old 04-02-2019, 01:19 PM   #1
W3gun's Avatar
Mini lite 2109s
I have a new 2018 mini 2109s. Used three times. I just got it out of storage and the first week it was in the driveway we had steady rain for couple of days. I was getting in the storage cabin and noticed the outdoor carpet wet. I unloaded the compartment out and water saturated all threw the rug bad. Water laying. On floor. Any idea where this water is coming from. You think it's the window in the front. It shows no water inside The wall and bed dry
W3gun is offline   Reply With Quote
Old 04-02-2019, 03:45 PM   #2
Franklins Mom's Avatar
Check your roof it could be a small crack in your sealant causing water to drain straight down into the area you are describing. We had the same thing happen after a heavy rainfall but above our skylight in the shower
Deb & Mike R
And the Fur Kid- Franklin the Springer Spaniel
2020 Rockwood Mini Lite 2109s
2017 F150 V6 3.5L Ecoboost Supercrew Short Bed
Franklins Mom is offline   Reply With Quote
Old 04-04-2019, 06:11 PM   #3
W3gun's Avatar
Thanks. I cleaned the water up dryer it out so no water on the walls except some moisture from dampness I guess. I went up the roof and saw the gutters filled with pine needles. It looked like the water trail ran down the side of the rv over the door. Also I did see and open spot on roof overlap toward the front joint. The soft compound there had opening I pushed it around to fill that hole to see. Is this a TPO roof or the other. Trailer is under warranty but dealer is 35 miles away. Do it myself
Old 04-04-2019, 06:18 PM   #4
Best to fix yourself as they won’t warranty crack in the sealant as that’s part of regular maintenance
Deb & Mike R
210, 2109s, lite, mini lite
