02-22-2020, 03:15 PM
#381
That will work. Make sure you order a switch plate for it also. They don’t come with one.
TT: Flagstaff 25FBLS
Previous TT: Jayco, Rockwood and Flagstaff
TV: 2017 F-150 SCREW, 3.5L Ecoboost, 10 speed, 3.55, 7000# GVWR, tow package.
02-22-2020, 03:35 PM
#382
Yes, I'm aware. Here's the switchplate:
https://highskyrvparts.com/search?se..._category=true
2011 Traverse LT, 3.6L, FWD
02-22-2020, 05:58 PM
#383
Originally Posted by rockfordroo
[emoji106]
02-28-2020, 03:17 PM
#384
Explore
Goodyear Endurance Tires Installed on 2511S
I had Discount Tire replace all 4 factory Castle Rock China bombs including the spare with USA made Goodyear Endurance tires, ST205/75 R14 Load Range D (8 ply).
I had 2 separate flat tires last year on the Castle Rocks. Fortunately both flats occurred while I was in RV Parks and I was able to get them repaired without delay. I had no TPMS at the time. I think I was very lucky I did not have the flats or a potential blowout on some remote highway.
China bombs never again! I will always run Goodyear Endurance tires. No guarantee of no flat but I have peace of mind knowing I’m running the Goodyear’s. I also now have the TST-507 TPMS with monochrome monitor and will put the TPMS caps on next trip out.
https://www.amazon.com/PACK-507-CAP-...%2C206&sr=8-14
03-04-2020, 05:11 AM
#385
I plan on replacing all the tires before my first trip. I'm glad Rockwood is now including TPMS with their campers. What's a rough estimate on the cost of those Goodyears mounted and balanced?
03-04-2020, 09:54 AM
#386
Explore
Welcome to the forum.
My OTD cost (mounted/balanced only) at Discount Tire was $689.91 for 5 tires. Additionally Goodyear offered a $50 rebate (prepaid Mastercard). The rebate expired Feb 29, but it does come and go.
03-06-2020, 11:29 AM
#387
We purchased an ADCO last April and it has held up very well. I keep the trailer covered and has done very well in high wind events.
03-23-2020, 05:08 PM
#389
Backup cam fuse
Originally Posted by Camp4two
Welcome aboard and congratulations on your new 2511S.
We have been using the Furrion observation/back-up camera for a month. Once installed the camera can be moved up or down to get your best viewing angle. Really like the observation feature to assist when changing lanes. The 4.3" monitor is small, but it is clear.
The SS refrigerator is not true SS. It is a panel that appears to look like SS. It can be scratched/nicked so be careful opening the doors when the slide out is closed.
Hi, new to the group and found this. Rockwood 2304KS and have no power to backup camera wiring (pre-installed) checked with voltmeter. Can't figure where the fuse is 'if' there is a dedicated fuse and/or where switch is. I checked all normal fuses and they seem to be working fine. THANKS IN ADVANCE. Rick
03-23-2020, 07:33 PM
#390
Did you turn on your TV's lights? Most cameras are powered from the trailers running lights, which are powered from the TV's running lights.
03-23-2020, 07:41 PM
#391
What he said.
Mine said it was wired to the box under the aframe but it was tied to the tow vehicle parking lights...not in the box. I tried to wire it seperately but it was tapped to the center clearance light.
03-23-2020, 09:58 PM
#392
Thank you all did not realize that. After I took off the bracket pulled out the wires took them apart so I can get the voltmeter on it I finally figured out I need to hook it up and turn on the TV lights. You learn by doing I guess thanks for all your help .
03-23-2020, 10:45 PM
#393
If you bought your 2403 from a dealer, he did a pretty poor PDI job, which seems to be the norm, unfortunately.
Feel free to keep asking questions. We've all been where you are.
03-23-2020, 11:05 PM
#394
No sir totally my fault. Did not realize that the electricity did not come from the fuse panel rather came from having the lights on when hooked up to your tow vehicle. Strictly my error.
03-27-2020, 09:01 AM
#395
Explore
Bedroom TV Mounted Outside
For 2511S/25FBLS owners who would like to move their bedroom TV outside, here is a photo of my 32 inch TV hooked up. I installed a second mounting bracket to lower the TV for better viewing and to get it away from the door opening and window. The same bracket fits both the bedroom swing arm mount and outdoor mount.
See Posts #369 and 370 for my mounting instructions and photos.
04-05-2020, 02:29 PM
#396
Replacement for Furrion Soundbar?
Hi Everyone,
One of the things I want to do to this trailer is replace the terrible sounding Furrion soundbar with something that sounds better than a 1950s era hand-held transistor radio.
Does anyone know if there are any compatible direct replacements?
Thanks in advance!
Rick
** Cross-posted in the Flagstaff 25FBLS forum, as it is identical to the Rockwood 2511S.
Rick & Marilyn
TT - 2019.5 Flagstaff MicroLite 25FBLS
TV - 2019 Ram 1500 Laramie 4X4
04-08-2020, 10:58 PM
#397
Explore
Originally Posted by rickj514
Hi Everyone,
Thanks in advance!
Rick
Agree. We both have the same Furrion soundbar. The sound quality is poor. When you remove the Furrion please Post back the model number. I think it is FSB24SA2C-BL.
X2. Does anyone know if there are any compatible direct replacements?
04-09-2020, 07:02 AM
#398
I would think that any sound bar that can fit the space would work.
If I remember correctly the connections are spade terminals. Not exactly the best but... so I doubt that there is an exact replacement but that shouldn’t be a problem to make up what ever connection you would need.
04-09-2020, 07:09 PM
#399
Originally Posted by getzold
Morning,
We have narrowed our search for a new, smaller TT to the Rockwood 2511. We are curious as to owners experience with the small rotating tables with the Theater Seating. They seem to be too small to really support using them as a table to eat at or use a laptop. Do you have recommendations for a TV type table or alternative?
We don't use the little tablet inserts. I bought two tv trays. Both store nicely beside the theater seats and work well.
04-12-2020, 12:40 PM
#400
We use ours. Obviously they don't hold more than a plate though. We purchased a small adjustable height table that works really well for 2 people when we are having a multiple plate meal!
This is the one we purchased: https://www.campingworld.com/outdoor...folding-tables
