Old 04-13-2020, 11:18 AM   #401
Explore
2511S/25FBLS Quick Reference Guide – Updated Apr 2020
THANKS! to all who have contributed to and viewed this thread.
As this thread continues to grow it will become more time consuming to find a particular topic(s) of interest without scanning all posts. This Guide should help make your task easier.
Note: Some categories have duplicate Post numbers. Categories are in alphabetical order and some are place holders for now.
Note: Posts in this Guide may also apply to the Flagstaff Micro Lite 25FBLS. The Rockwood Mini Lite 2511S and Flagstaff Micro Lite 25FBLS are essentially the same trailer under different brand names.
I will update it periodically. Any suggestions to improve it are welcomed.
Category/Posts:
APPLIANCES
Refrigerator/263-265, 291
AXLES/SUSPENSION/FRAME
CO/PROPANE
CO/Propane Detector/89, 98
ELECTRICAL
Battery/100-101, 180-181, 236, 239-241
Breakers/Fuses/Surge Protector/91-92, 180
Converter/211-212, 215
Generator/181
Inverter/27, 180, 182, 186-189
Solar/180, 366-367
ENTERTAINMENT/Wi-Fi
BR TV/369
LR TV/166-167, 249-251, 253, 301, 371-372, 374, 396-398, 400
Outside TV 295-297, 368, 370, 395
Wi-Fi Ranger/105-109
EXTERIOR
Front Window/174, 176
Patio Awning/Slide Toppers/245, 323-324, 365
Repairs/134-135
Screen Door Handle/71-72
Trailer Cover/325, 387
GENERAL INFORMATION/ACCESSORIES
2019/2019.5 2511S/1, 5-14, 19-22, 26, 32-35, 37, 40, 44, 47, 49, 51, 90, 102, 114, 122, 163, 227-231, 233, 246, 343, 345, 347, 363-364, 388
2019 2506S/15-18
2020 2511S/141, 190-193, 224-226, 237-238, 285
Backup & Observation Camera/102-103, 154-158, 389-394
BBQ Grill/94-97
Bike Racks/82, 185
Carbon Steel/Stainless Fasteners/266-268, 270-271, 273
Cargo Carriers/184
Quick Reference Guide/93, 199, 202, 205, 300, 401
HEATING/COOLING
Air Conditioner/139-140, 375-376, 378, 380-383
Furnace/
Thermostat/143-145
INTERIOR
Bathroom/168-170
Bedroom/28-31, 42-43, 311-312, 316-318, 321
Cabinets/232, 234-235, 329, 331, 333-338
Kitchen/
Living Room/53-55, 117-118, 151-152, 196-197, 209-210, 213-214, 286-290, 292-293, 329, 399
LEVELING JACKS
Power Stabilizer Jacks/44
MODIFICATIONS/UPGRADES/CHANGES
Digital Thermostat/143-145
Kitchen Countertop Extension/142, 149-150, 198, 200,203-204, 232, 254-255, 260
Solar, Inverter and Batteries Setup/180-181
Other Modifications/153, 280, 294, 298-299
PRE-DELIVERY INSPECTION
General/339-342, 344, 350-351, 360
PLUMBING
Antifreeze Inlet/Winterizing/45-46, 48-50, 52, 74-75, 77-79, 136-138, 353-359, 361
Fresh Water Inlet/Tank/Drain/63-64, 69, 248, 256-259, 274-275, 306-308
Gray Water Tanks/Drains/131-132
Low Point Drains/56-62
Sewer Hose/23-25
Water Filter/Bypass/65-68, 70, 110-113, 115-116, 119-120, 123, 164-165, 217-223, 261-262, 277-279, 377, 379
ROOF
RUST PREVENTION
General/266, 281-284
SLIDE OUTs
Living Room/Wardrobe/87-89, 104, 133, 146-148, 206-208
Living Room Slide Out Manual Crank/124-129
Wardrobe Slide Controller/130
TIRES/WHEELS
Spare Tire Carrier/178-179
Tires/Wheels/73, 76, 80-81, 384, 386
TPMS/385
WARRANTY ISSUES
General/310
Extended Warranty/314-315-319
WEIGHING/LOADING/TOWING
Bumper Support/172, 175, 177, 183, 242-244
Bumper Receiver Hitch/183
Frame Mounted Receiver Hitch/194-195
Tongue Jack/247, 373
Tongue Weight/83-86, 173
Towing/39, 41, 99, 159-162, 326-328, 330
Camp4two is offline   Reply With Quote
Old 04-16-2020, 01:51 PM   #402
Explore
2511S/25FBLS Pass-Thru Doors Magnetic Latch Installed
Sometime after the 2019.5 2511S/25FBLS models the factory started installing a magnetic door latch on both pass-thru doors. See video timer at 4:17-4:20.
Here is the magnetic latch. I bought two on Ebay:
https://www.ebay.com/itm/Baggage-Doo...wAAOSwZcZZqWV5
The Ebay latch comes with supplied screws but the heads are not color matched to the hardware. I bought color matched screws a Lowes, 9x3/4 for the door and 9x1 for the trailer wall.
This thicker magnetic door latch is necessary for the door to clear the trailer’s running light lens.
I eyeballed lining up the magnet and striker plate, used a sharp punch to mark holes for drill bit. Drilled all holes using a 3/32” drill bit. Gorilla glued all screws.
No more wind blowing my doors while getting stuff from storage or when I want to leave them open.
ID:	227026   Click image for larger version
ID:	227027   Click image for larger version
ID:	227028   Click image for larger version
ID:	227029   Click image for larger version
Old 04-18-2020, 11:15 AM   #403
Explore
Protectants, Lubricants and Cleaners Used on 2511S
Here are the protectants, lubricants and cleaners I currently use on our 2511S. There are many good products out there. I have been using these products over 8 years on 3 trailers.
1. All seals (slide-outs, doors, etc.); Awning and slide toppers top fabric UV protection
Protectant: Aerospace 303 UV Protectant
https://www.amazon.com/303-30320-Pro...s%2C199&sr=8-1
Protecting awning and slide toppers videos:
2. Awning mechanism and arms; Slide toppers mechanism (each end of roller)
Lubricant: DuPont Teflon Silicone Lubricant
https://www.amazon.com/DuPont-Teflon...s%2C207&sr=8-1
Dometic awning lubrication video:
3. Living room slide-out gears, gear teeth and rails (Do not use grease); Power or Manual Stabilizer Jacks (Do not use grease)
Dry Lubricant: Protect All Slide-Out Dry Lube Protectant
https://www.amazon.com/Slide-Out-Dry...s%2C195&sr=8-5
Slide-out gears lubrication video:
4. Wardrobe Schwintek Slide-Out
Lubricant: CRC Power Lube Industrial High Performance Lubricant with PTFE
https://www.amazon.com/CRC-Industria...s%2C200&sr=8-1
Schwintek lubrication video:
5. Door Key locks
Lubricant: Any powdered graphite lubricant
https://www.amazon.com/Graphite-Lubr...s%2C202&sr=8-2
6. Wheel bearings
Lubricant: Lucas Red “N” Tacky #2 or Mobile 1 Synthetic Grease
https://www.amazon.com/Lucas-Oil-100...s%2C204&sr=8-3
https://www.amazon.com/Mobil-105527-...s%2C228&sr=8-4
Wheel bearings lubrication videos:
7. Tires
Tire maintenance video:
8. Roof
Cleaner: Dawn Dish Soap or Spic and Span
Protectant: Dicor Roof-Guard Rubber Roof Protectant
https://www.amazon.com/Dicor-Corpora...s%2C202&sr=8-4
Dicor video:
9. Exterior Walls
Cleaner: Aero Cosmetics Wash Wax All
https://www.amazon.com/Aero-Cosmetic...s%2C198&sr=8-2
Video:
Old 04-19-2020, 03:16 PM   #404
2plus1's Avatar
Thank you to Camp4two for this thread. We have a new untried and untested 2020 2511S sitting on the pad in our back yard. We brought it home on March 6th. We all know what happened right after that. The snow is just about gone here and come May 1st I will de-winterize it and make sure those systems are ready. We are fortunate in that our yard is big enough to 'camp' in. All Provincial and Private camps are shut down here in Saskatchewan. Timing is everything.
Paul / Carole Ann and 'Monte' the Goldendoodle
2023 Rockwood Ultra Lite 2608BS
2020 Rockwood Mini Lite 2511S
2017 Rockwood Mini Lite 2502KS
2012 Ram 2500 6.7L Diesel
2plus1 is offline   Reply With Quote
Old 04-20-2020, 09:11 AM   #405
Explore
2plus1, You’re welcome and welcome to this forum. I think you are really going to enjoy your new 2511S. DW and I have owned our 2019.5 2511S for 18 months and love it. Most of our favorite campgrounds are also shut down. We anxiously wait for them to open up.
FR made some nice improvements to the 2020 2511S/25FBLS that we wish we had on our trailer when new. Optional roof mounted solar prep, standard 2 inch hitch receiver, larger FW tank drain valve, water pump moved from back to front of trailer (much easier access), magnetic latch on pass-thru doors, TPMS, fireplace, drop down kitchen counter extension and a pantry style cabinet to name a few.
I hope this thread becomes a useful tool. Please Post your questions/comments. Many forum members are here to help.
Happy camping (someday).
Old 04-20-2020, 09:53 AM   #406
2plus1's Avatar
Campfire Talk
Thank you again Camp4two. This thread and the forum have already been very helpful and useful. Our 2502KS had one of the defective Ignitor boards on the water heater. The forum helped me to diagnose the problem, the dealer shipped me a new one and I changed it out myself. That's right I was 'lurking' for four years. Your thread and our new purchase convinced me it was time to throw my hat in the ring. My hope is that I can be helpful to some of the 'newbies'. The Signature space is very limited and does not allow for the full story with an old-timer like me. There are four more RVs and 25 years on a Sailboat that I could add which is just camping on the water. Before that Carole Ann and I had a fold-out camper, a couple tents and it all started back in the '50s with my Mom and Dad in a home built camper. We are Vagabonds, in fact that was the name of the boat, and have explored the USA from California to Georgia. We retired in 2006 and did the Snowbird thing with the motorhome but found that sitting in one place for five months wasn't for us. With a new unit we always do our 'shake down cruise' at home where I have the opportunity to fix what might need fixing. As soon as the weather settles down and the temp stays above 32F overnight we'll do that. Meanwhile I'll just look at it in the back yard and hope we all make it through these trying times. Stay safe everyone. Paul
Old 04-26-2020, 02:29 PM   #407
Explore
7 Way Trailer Plug Holder Installed
The factory started installing a 7 way plug holder on their 2020 Mini/Micro Lite trailers. Another good idea so I put one on my 2511S to keep the connection dry.
Plug holder:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Screws: #12 x 1” hex metal
Socket: 5/16”
Drill bit: 5/32”
I gorilla glued the screws and painted the screw heads black.
ID:	227691   Click image for larger version
Old 04-26-2020, 05:21 PM   #408
2plus1's Avatar
So that's what that thing is ! Just kidding, been using it since we brought it home. I used to wrap the cord around the jack post and let it hang down under the propane bottles to keep it out of the rain. I have to admit that there was a time or two that I got to the first stop sign and noticing the extra brake pressure needed realized it was still there. I am hoping that this will remove that possibility.
Paul
Old 05-05-2020, 09:45 PM   #409
Explore
Hot Water Tank Two Valves Direction
If your 2511S/25FBLS has two (2) HW tank valves, here are the correct valve positions for (1) normal operation and (2) bypass .
1. When the two valve handles point to the HW tank the valves are in normal operation (water enters HW tank).
2. When the two valves face parallel to the hoses the valves are in bypass. (no water enters the HW tank).
• Bypass is used during winterizing if antifreeze is used (no antifreeze enters the HW tank).
• Bypass is used during sanitizing (no chlorine bleach solution enters the HW tank). This is an option, the HW tank can be sanitized.
I sometimes lose track which are which so this post serves as a reference.
Name:	HW Tank Normal Operation Valves Direction.jpg
Old 05-10-2020, 11:00 AM   #410
The_Dude_Abides's Avatar
That is a great idea for the switch. I too agree the switch is much better by the door. I tried to find the Diamond switch you listed but had no luck finding it. Any chance you might be able to look it up or where you bought it?
The_Dude_Abides is offline   Reply With Quote
Old 05-10-2020, 11:50 AM   #411
Funengineer's Avatar
Mini Lite 2511S Owners Thread
Here’s one. https://www.etrailer.com/Accessories.../37212225.html
I think I bought mine at Camping World.
TT: Flagstaff 25FBLS
Previous TT: Jayco, Rockwood and Flagstaff
TV: 2017 F-150 SCREW, 3.5L Ecoboost, 10 speed, 3.55, 7000# GVWR, tow package.
Funengineer is online now   Reply With Quote
Old 05-10-2020, 03:07 PM   #412
Explore
Replaced Entry Door Stopper with a Bumper Door Holder
On windy days our 2511S entry door moves a lot even with the stiff friction hinge. I replaced the door stopper with this low profile bumper door holder:
Wall mount:
I used the larger supplied screw on the wall side in the same hole as the old door stopper. The screw goes in very tight into the rubber bumper. I gorilla glued the screw and back of the bumper and painted the screw head black.
Entry door mount:
I eyeballed lining up the male end and marked the hole with a sharp punch.
I used a 1/8” drill bit as a tap and used the supplied screw.
I gorilla glued the screw and back of the male end and painted the screw head black.
Wait at least 24 hours for the glue to dry before inserting the male end into the bumper.
Name:	Old Door Stopper.jpg
ID:	228761   Click image for larger version
Name:	Bumper Door Holder 1.jpg
ID:	228762   Click image for larger version
Name:	Bumper Door Holder 2.jpg
ID:	228763   Click image for larger version
Name:	Bumper Door Holder 3.jpg
Old 05-11-2020, 07:59 PM   #413
Originally Posted by Freetyme View Post
We ordered our 2511s with the theater seats, no regrets. Have a height adjustable folding table that stores nicely between the seat and fridge, bought at Walmart. There are also removable pivot snack trays for both outside arms. One of the reasons we moved up from the 2109s was the uncomfortable jackknife sofa and clunky table.
Great info. Do you happen to know what the name or model of the folding table is??
Old 05-12-2020, 12:43 AM   #414
Explore
The folding table from Walmart is at Post #118 in this thread (click on link):
https://www.forestriverforums.com/fo...169224-15.html
It is what we use with our HAB sofa in our 2511S and works great.
Old 05-15-2020, 08:47 AM   #415
2plus1's Avatar
Camp4two, I now have the new door bumper, stopper. Great idea BTW, so much better than the old type that still allowed the door to rattle. Question: What type of Gorilla glue did you use? It appears to be black in your pic. Did you paint that also?
Old 05-15-2020, 09:45 AM   #416
Explore
The gorilla glue bleeds into the rubber stopper a little causing the black appearance around the rim. Use a little bit glue on the back of the stopper. I did not paint the stopper, just the screw head.
Name:	Clear Gorilla Glue.jpg
Old 05-17-2020, 11:59 AM   #417
Explore
Replaced Outdoor Shower with a Hose Sprayer
We don’t take outdoor showers so I decided to make better use of the outdoor shower compartment on our 2511S.
Thanks to 01trundra and 5picker in this thread Posts #3 (photos), #4 and #6.
https://www.forestriverforums.com/fo...es-205843.html
The shower hose replacement on Amazon:
https://www.amazon.com/Purelux-Stain...xpY2s9dHJ1ZQ==
The brass garden hose adapter fitting from Home Depot:
https://www.homedepot.com/p/Everbilt...1799/207176334
Already had the adjustable brass hose nozzle.
I replaced the outdoor shower door key lock with thumb lock. Didn't need a key lock there.
Name:	Outdoor Spray Hose.jpg
ID:	229260   Click image for larger version
Name:	Outdoor Shower Door Thmb Lock.jpg
Old 05-18-2020, 12:20 PM   #418
Explore
New 2021 Rockwood Mini Lite 2511S
The 2021 2511S models are out. This one was manufactured 3/13/2020:
Old 05-19-2020, 03:06 PM   #419
I bought the cargo carrier at Harbor Freight and was cheap and can load up to 500lbs.
https://www.harborfreight.com/500-lb...ier-66983.html
The spare tire was in the way so I need to also buy the hitch extender which made things work perfectly.
https://www.harborfreight.com/12-in-...der-69882.html
I plan to eventually store my 3500 generator on it with a non-descript cover and chain lock. It is right near the electrical plug of the 2511S in the back as well. It also is far from the bedroom so you won't hear it much either.
Old 05-20-2020, 05:49 AM   #420
Unless it's fixed permanently, you may be better off moving the spare to one side. Adding the extender will potentially add a LOT of leverage, effectively multiplying the weight of the generator to greater than the capacity of the accessory hitch.
TV: 2021 Ford F-150 4WD XLT Crew w/ 3.5L EB & HDPP, payload: 2,416#.
Camping nights: 2021, 52; 2022, 99; 2023, 88; 2024, TBD (Est: 80+)
chriscowles is offline   Reply With Quote
lite
