I'd get a stronger double sided tape. Command has outdoor tape that works well in our shower. I think Gorilla tape and 3 M have similar tapes.
You have to clean the surface with alcohol, allow it to dry, then follow the directions on the tape. Most say to hold it firmly against the surface and give it 24 hours before you use it. When we've had tape failure, it's usually operator error.
You really don't want to drill into that shower. There is the possibility of cracking the shower or drilling through the outside of the rig.
2015 Dynamax REV 24TB class C
