Old 11-01-2017, 10:33 PM   #1
Murphy Bed Legs Rolling Under
I am having trouble keeping the leg on my Murphy bed from rolling under and not stayin firmly on the floor. What have others done to keep them square. I have thought of adding magnets. Or is no one else having this problem.
kamp-n-head is offline   Reply With Quote
Old 11-01-2017, 10:56 PM   #2
Never heard of this issue. Do you have the round rubber "foot" on the bottom of your legs? I would think that would keep the legs from folding under.
Note that older units (before spring 2017) had luan and foam floors and a number of us with the round rubber feet removed them and installed felt on the bottom of the legs. The round rubber feet did not have as much square area as the entire leg does, and it was creating an impression in the floor; the felt allows the entire area of the leg to rest on the floor, resulting less less pressure per square inch.
The newer units have 5/8" plywood for the floor, so the pressure is a non-problem (so far as I am aware).
2011 Traverse LT, 3.6L, FWD
Old 11-01-2017, 10:58 PM   #3
I have the 5/8 floor, but I still removed the rubber foot and added the felt pad. My couch cushions keep the bed from going all the way down
Old 11-01-2017, 11:01 PM   #4
Never heard of the cushions keeping the legs from going all the way down. Maybe you should put the rubber foot back on.
Old 11-02-2017, 10:55 AM   #5
I had the same problem with my new 2304ks I put the felt on so the floor would not dent. If you make sure it is square and hold down when you get on bed, after a few times the cushions get mashed down and get a memory. Another thing that will help is if you put down a non slip runner rug in front of couch this holds the legs well also.
Beck
Beck is offline   Reply With Quote
Old 11-02-2017, 12:43 PM   #6
Beck
I was hoping it would mash down over time. Only sleep in it 3 nights so far.
Old 11-02-2017, 01:27 PM   #7
We've got the thicker floor but replaced the plastic buttons with thick sticky-back felt anyway after hearing about floor dents. We've had the same issue with the legs sliding in a bit, usually when one of the mutts plops down at night against the legs. I'm not too worried about it since the couch is there to prevent the bed from dropping too far. I've thought of different ways to lock them in place - lots of options there (e.g., window-type latches or locking tabs) but since it hasn't been a big problem it's low on the list of projects.
Jack & April Connell
2017 Rockwood Mini Lite 2104S
Tow Vehicle: 2014 Jeep Grand Cherokee diesel
Blog for our trailer trips: www.jackandaprilblog.com
jackconn is offline   Reply With Quote
Old 11-03-2017, 09:35 PM   #8
Max the Mini's Avatar
We put our rugs under the feet or rubber pads. We had problems with it moving the first night. Now as mentioned above we make sure it is square and push the bed down.
Max the Mini is offline   Reply With Quote
Old 11-25-2017, 02:08 PM   #9
So last night must have been my magic night. The leg end stayed in place.
bed
