Old 08-01-2021, 12:34 PM   #1
My AC is terrible
I read post after post about how bad the AC functions in campers. Why is that? Mine barely blows cool air. My sister has the same size camper as me, and she can hang meat in there it’s so cold. It’s an older camper as well. I don’t get it
OburgOrange is offline   Reply With Quote
Old 08-01-2021, 02:11 PM   #2
Trailer Park Supervisor
NJKris's Avatar
When they work, they work pretty well. But they are cheaply made, therefore don't last. RV'ing is apparently a sport of kings and sultans, supported by mountains of cash thrown into it by an increasingly eager 'donor' group.
Yes, I drink the water!
NJKris is offline   Reply With Quote
Old 08-01-2021, 02:38 PM   #3
Cousins
I don’t know how old your AC is but mine is 6 years old. I just had it serviced and Freon added. It cools really well now. $100
2015 Forest River Cherokee Grey Wolf Limited
2011 F150 Supercrew Ecoboost Lariat 4WD
Eddie and Catherine is offline   Reply With Quote
Old 08-01-2021, 02:54 PM   #4
My AC was very low on freon. My mobil tech would not just fix and add freon. He said he would lose his dealership license from Coleman if he just added freon. No way to add just replace. Cost me $1500.
2015 Flagstaff 26VFKS
TV - 2014 F150 Crew Cab 5.0L
WDH - 1,200 Equalizer
txredfish is offline   Reply With Quote
Old 08-01-2021, 06:28 PM   #5
Retired JSO's Avatar
I doubt your tech added Freon as most all RV units are sealed having no service ports. One would have to cut the lines, braze service ports, vacuum and totally refill the system. [moderator snipped unfriendly comment]
Retired JSO is offline   Reply With Quote
Old 08-01-2021, 07:46 PM   #6
Originally Posted by Retired JSO View Post
I doubt your tech added Freon as most all RV units are sealed having no service ports. One would have to cut the lines, braze service ports, vacuum and totally refill the system. --moderator snip--
Bullet taps are like $5. I’ve seen them eke out a few more years from a system with a small leak. Not saying it’s legal to fill a leaking system, or recommended, just that a self piercing tap and some refrigerant could have been added for $100.
MstngLX50 is offline   Reply With Quote
Old 08-01-2021, 10:17 PM   #7
Enjoying Life
Check out this fix. I did it on mine and it made a world of difference
2022 Rockwood 2109S
Previous: Rockwood 2608WS, 2608BSD
2006 Durango HEMI
TeachTexas is offline   Reply With Quote
Old 08-01-2021, 10:34 PM   #8
NMWildcat's Avatar
I have had techs add ports to two different a/c units over the years to avoid having to replace the entire unit. They worked great until I sold the RV. Was fairly cheap. It does happen.
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
Old 08-02-2021, 06:36 AM   #9
nomad297's Avatar
One thing about air conditioning that I have never been sure of is related to the difference in the temperature of the cooled air versus the “ambient” air. I have always understood that the cooled air should be somewhere around 20° colder than the “ambient” air, but I have never known if the “ambient” air temperature is measured outside or inside.
For example; if the ambient temperature is measured outside, in the shade on a 100° day, the inside temperature would never get below 80°, but if it is measured inside, the ambient temperature should get colder and colder as the air conditioner is continuously being fed increasingly colder (ambient) return air.
Which is it?
Bruce
Old 08-02-2021, 06:52 AM   #10
Flybob's Avatar
Moderators Note.
This Thread morphed from a discussion on AC performance into personal attacks.
It has been cleaned up and re-opened.
Please leave the moderating to the site team.
If you have issues with someone's comment use the triangle with an exclamation mark inside to bring it to our attention PLEASE!
Now back to our regularly scheduled program...
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 08-02-2021, 10:51 AM   #11
NJKris's Avatar
Which is it?
Bruce
That's actually a good question and one I've wondered about as well. I think there are other factors at play as well, like sunlight. My trailer temp will go 12 degrees above outside temp in full sun light without A/C on or any ventilation (used to go 17 higher before I stuffed a skylight pillow up there). Typically AC guys seem to measure the differential between supply and return, so I believe that is what they mean by 'ambient'.
Old 08-02-2021, 12:22 PM   #12
We also had our independent RV repair shop add a valve and Freon to our AC about 2 years ago and has worked much better since then.
lucky55616 is offline   Reply With Quote
Old 08-02-2021, 12:54 PM   #13
I'm knocking on as much wood here as possible... I've owned 15+ R/Vs throughout my camping experiences (PUPS, truck campers, motorhomes, TT and 5th wheels) and all my A/C units have worked and cooled without issues.
I don't know that everyone has mechanical issues as much as expectation issues.
The walls of these R/Vs are extremely thin and poorly insulated. Couple that with parking in the direct sun (no shade cover) and you'll believe it isn't working when it really is doing all it was designed to do. Many folks don't use the 'Quick-dump' feature and blow all that hot air in the roof ducts into the R/V, therefore actually RAISING the temperature when they first turn on the A/C.
Many folks also wait too long to turn the A/C on during the day. Don't wait until it's too uncomfortable to start the A/C. If we run ours early, it keeps the temperature during the rest of the day, much lower than if we wait until it already too hot.
Does that mean there isn't issues sometimes?... no... but sometimes it is simply user expectations that can never be met.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=101
Old 08-02-2021, 01:28 PM   #14
Maybe a silly question, but when was the last time you cleaned your filters?
2018 Rockwood Signature Ultra Lite 8311WS
2014 Coachmen Apex 215RBK
2018 GMC Sierra 2500HD SLT Duramax
Chazman is offline   Reply With Quote
Old 08-02-2021, 02:21 PM   #15
Temp Difference
Run your AC on high for 5 minutes and check the temp of the air coming out of the vent, then check the air temp of the air going into the return vent. Ideally it should be around a 18 degree difference. If it is significantly less, your AC is the problem. If it’s around 18 or better, your AC is ok. Problem is it takes a long time for the wood and furniture to come up to a cool temp after traveling in the hot sun.
Cajunrver is offline   Reply With Quote
Old 08-02-2021, 02:31 PM   #16
NJKris's Avatar
Always better to open all windows/door when hot inside from travelling, turn exhaust fan on, and purge that hot air before attempting to cool with A/C. Same concept as cooling a hot car. You don't just jump in and turn AC on, you open windows while driving to purge most of hot air first while running AC in non-recirculate mode, THEN close windows.
Old 08-02-2021, 06:37 PM   #17
Where is "ambient?"
Which is it?
Bruce
Bruce, the 20° drop appears across the evaporator coil. Since an RV refrigerator only draws from the inside (no fresh air blend option), you would take a measurement away from an outlet and compare it to a measurement near an outlet. You would expect to see about a 20° difference.
Bruce
Exactly. Since the "ambient" is indoors, the cooler it gets, the cooler the maximum achievable temperature is.
Extending your example, if it's 100 F inside the trailer, the outlet temperature would be 80 F. As soon as the temperature drops to 99, the outlet temperature would be 79 F.
This is within a limited range. As the air cools, there's less heat in it to extract. A heat pump is an air conditioner running in reverse. They are not very effective in cold winter temperatures. There's just not enough heat to extract from the (outside) ambient to bring into the house. I seem to recall that when it's near zero the duct outlet temperature is about 70 F (which feels pretty cool in the winter when the room is 65 F and it's blowing on you).
Larry
Larry-NC is offline   Reply With Quote
Old 08-03-2021, 07:29 AM   #18
ARLO
We finally had to replace our Coleman after 11 years in a lot of camping. When we ordered the unit we ordered the 15,000 BTU instead of the 13,500 BTU. It made a big difference for cooling.
rlocicero is offline   Reply With Quote
Old 08-03-2021, 09:54 AM   #19
D W
D W's Avatar
That's either collusion, or the tech would rather be a "dealer" as opposed to a HVAC Tech.
2016 Salem 27RKSS
D W is offline   Reply With Quote
Old 08-03-2021, 01:13 PM   #20
D W
D W's Avatar
That's a very prophetic statement
2016 Salem 27RKSS
