Old 09-23-2020, 11:15 PM   #1
New griddle in rockwood
Does anyone else hate the new griddle in the Rockwood. I think it's a bad design. Should come with a lid, flame goes out when it's windy, and nothing too keep the heat in because its wide open. Any suggestions to make this work better. My portable BBQ with a lid works better.
sims is offline   Reply With Quote
Old 09-24-2020, 12:03 PM   #2
I have a new Rockwood on order that is supposed to come with one. I don't have it yet. However, I do already have a 17" Blackstone. The griddle that comes with the Rockwood is supposed to be a copy of the 17" Blackstone.
I personally love mine. It is extremely versatile. Since it is a copy of the Blackstone, I am not sure if the Blackstone accessories fit, but if they do, they sell a hood for it.
https://blackstoneproducts.com/produ...ease-unit-only
If you have a dollar tree by you, go purchase 6 or 8 Chopper/Scraper. They are $1 a piece. They can hang over the edge of the griddle and block the wind so the griddle doesn't blow out. They are also great for scraping it off after cooking.
https://www.dollartree.com/cooking-c...crapers/226405
There is also a Blackstone users group on Facebook that may be worth joining. Lots of recipes and idea's on there. I have a 28" one for my house and the 17" from my old trailer.
NEOCamper is offline   Reply With Quote
Old 09-28-2020, 03:11 PM   #3
We love ours (2020). I'm just not going to hang it on the side of the rv. We are ordering the table that is half metal grate and half pic plastic (about $42).
My son has a Blackstone. There's not that much difference...at least not enough to get me to go out and buy one.
Apsaunders is offline   Reply With Quote
Old 09-28-2020, 03:34 PM   #4
I love mine but am aware of the need for a windscreen. I just ordered the wind screens below. They're intended for a larger griddle but I think they'll work. The long panel is about the same width as the griddle that came with the trailer.
- 2016 Ford F-150 SCrew Lariat 4x2 3.5L Ecoboost, 1700# payload
- 2020 Rockwood 2507S
chriscowles is offline   Reply With Quote
Old 09-28-2020, 06:16 PM   #5
Oops. Forgot link.
https://www.amazon.com/dp/B08B3Z7F6N
Old 09-28-2020, 06:23 PM   #6
Thks for suggestions
Old 10-02-2020, 01:41 PM   #7
This is the wind screen I linked above. It's intended for a 36" griddle so you end up with an extra piece of the wide section, but it fits well.
The louvers cut into the screen don't line up with the gap between the griddle and the body but I wouldn't want them to, anyway. There's plenty of air access on the front and corners, and there are louvers in the body itself.Click image for larger version
ID:	240411Click image for larger version
Old 10-10-2020, 05:11 PM   #8
Does anyone know how to connect a 1 lb propane tank to the back of this suburban griddle?
dmousley is offline   Reply With Quote
Old 10-10-2020, 06:22 PM   #9
You can assemble it from these parts. Other variations and sources are available.
The 1#-20# adapter may not have a shut-off valve. If so, that's potentially dangerous because propane will flow uncontrolled if you connect the adapter to the cylinder before connecting it to the regulator. Attach it securely to the regulator before connecting the bottle.
1 lb to 20 lb Propane Tank Adapter for Disposable Throwaway Cylinder
and
Stanbroil 6 Feet Propane Regulator Hose - 1/4" Female Quick Connect x Acme Nut
Edit: I don't recall if the griddle has the female quick connect. If so, this will serve the purpose:
Sturgisafe Lp Gas 1#Throwaway Bottle 120 Hose 100476-120PKG
rockwood
