Old 03-03-2021, 07:40 PM   #1
Newbie: How to use a heater?
I cannot find any video online on the geo pro . How to turn on the heater? I have never done this before. Do I need to switch something on first before I switch the thermistats to a high heat position?
I don't know if this is correct. But I Tested out the GAS and it work fine. So I know the propane is getting GAS into the stove. So I switch the thermistats to a hot position and I can feel hot air coming out. But there is a smell I don't like. maybe its just me or this is a new geo pro.
Just wanted to be safe.
Question:
Am I smelling Carbon Manoxide? How do I tell if the heater is running correct?
Thank you.
2021 Geo Pro 20BHS
2020 Tacoma TRD SPORT 4x4
aboyz is online now   Reply With Quote
Old 03-03-2021, 07:45 PM   #2
If it's your first time running the heater, you're smelling the oils that coat the unit when it's produced. Open the windows and the smell should go away after a few minutes.
You can't smell carbonmonoxide.
2015 Dynamax REV 24TB class C
Reverse_snowbird is offline   Reply With Quote
Old 03-03-2021, 07:49 PM   #3
httntheroad's Avatar
You know it's carbon monoxide. 2 words.
httntheroad is offline   Reply With Quote
Old 03-03-2021, 07:50 PM   #4
Retired JSO's Avatar
Carbon Monoxide has no smell. Thatís why you also have a CO Detecter . Smell is just the new equipment smell that will disappear after a few minutes.
Retired JSO is online now   Reply With Quote
Old 03-03-2021, 07:52 PM   #5
Originally Posted by Retired JSO View Post
Carbon Monoxide has no smell. That’s why you also have a CO Detecter . Smell is just the new equipment smell that will disappear after a few minutes.
Thank you all!! make me feel safer!! let me open it again and open up the windows.. thank you..
I don't need to turn anything else beside just turning on the thermostats? that easy?
2021 Geo Pro 20BHS
Old 03-03-2021, 09:42 PM   #6
Yes, that easy-just like home- as long as you have shore power (plugged into an AC electrical unit). Your heater fan will drain your batteries in a day or two if you are camped in cold weather unless you are able to recharge the batteries via a generator, solar, or shore power.
2205S Rockwood
F 150 Lariat 3.5 Eco Fx4 Max Tow
Equalizer WDH, 1809 lb payload
flyflotrtim is offline   Reply With Quote
Old 03-03-2021, 10:12 PM   #7
bikendan's Avatar
Question:
Thank you.
Doesn't your home have a thermostat?
Old 03-04-2021, 10:05 AM   #8
Thanks. I obviously missed the spacebar. Flawed human here.
heater, newbie
