03-22-2021, 09:53 PM
Newbie Questions on grey tanks
Hi everyone,
We recently got an 8336BH bunkhouse with 4 tanks they each has its own dump valve... 2 Grey, 1 Galley and 1 Black. The 2 Grey and 1 Black are in the same location, the galley one is more in the back.
We've been camping a couple of times with it now and the first time we went we tested and filled about 3/4 all the tanks, mostly to test the sensors, or so I think I did maybe?
This last trip the Grey tank #2 didn't fill up when #1 overflowed a bit as I noticed from the bathroom sink as i was using it.
I thought it was automatic for each grey tank to switch from one to the other when the first one fills up.
Did i miss a switch maybe?
Any idea why #2 didn't start filling when #1 filled up completely?
Thank you all in advance!
03-22-2021, 10:16 PM
Just a guess here, but I'll bet the grey tank #2 is for a washing machine only and is completely separate from grey tank #1 which is for bathroom sink and shower.
03-22-2021, 10:29 PM
And you are probably right! There's a hook up for a washer/dryer too on the RV. Probably that's what it is then. Thanks!
03-22-2021, 10:54 PM
Also, I don’t think you missed a switch. Most tanks grey or black are plumbed separate. They don’t automatically fill when one is full. FYI, galley is grey also. So looks like you have 3 grey tanks and 1 black tank....
03-22-2021, 11:42 PM
Camping the Natural State
Pretty sure that camper has 2 gray tanks, 1 black tank, and 1 fresh water tank. The kitchen sink is on 1 grey tank. Shower and bathroom sink on the other.
2021 Rockwood Ultra Lite 2614 BS
03-22-2021, 11:47 PM
Just going by his op that he has 4 valves..freshwater does not have a valve...your scenario matches what I have but I certainly don’t know all the different set ups on RVs... hopefully the op will come back and clarify
03-23-2021, 12:19 AM
Correct, i have 4 valves plus the freshwater tank. 1 grey valve is in the back and labeled "galley tank", so i assume it's for just the one kitchen sink, then i have two more Grey valves and 1 Black one coming out of 3/4 to the front, under the bathroom area, of these, one valve labeled "Grey Tank #2", one labeled "Black Tank" the other grey valve (that works) had no label, but i know it's #1 from emptying and verifying the inside control panel. In addition there a fresh water tank with its own flushing outlet all the way in the rear under the outside kitchen (no sink).
03-23-2021, 12:35 AM
Thanks for clarifying your tank setup. One f your original questions was about the tank filling and not automatically overflowing to another tank. I’ve never heard of this and usually all tanks are plumbed separately.
I assume all the tanks empty out one outlet? If that is the case some folks add one of these to that outlet and then can open two grey tanks and let the share the grey water. If one fills and another is not then if you added this extra valve you can do this without grey water spilling out when you remove the sewer cap.
It is also just good practice to add one of these as there are times when a valve may not seat correctly. Nothing worse than removing that cap and black or grey water gushes out..
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
03-23-2021, 12:50 AM
Fantastic thank you! That's exactly what I was looking for. I was going to buy that add-on valve to avoid messes but now I see how it can help me maximize the use of both my grey tanks. Much appreciated, love this community, everyone always so helpful, here and at the campgrounds
03-23-2021, 05:34 AM
Well my freshwater tank has a dump valve !
03-23-2021, 02:15 PM
Going to start calling you lucky...lol.. I did not know fresh water tanks have knife blade valves like the the sewer and grey valves. Mine has a small 45 degree twist valve under RV but not a knife blade valve. Learn something new on this forum everyday. I wish it did have a large dump valve like yours...trink39:
03-23-2021, 02:59 PM
We have two grey tanks but 1 is dedicated to the washer that we don’t have. This may be similar to your setup. We use that screw on valterra valve at the sewer hose connection. Close the screw on valve and open the two grey valves. This will connect the two grey tanks and give you increased grey tank capacity. Keep the black tank valve closed while you do this.
To drain the tanks close the two grey tank valves. Then open the twist on valve and it will drain the grey water in the connecting pipes. The proceed as normal. Drain black the the greys.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
03-23-2021, 03:10 PM
I didn't know any Forest river products had this but I know Grand Design does. Slightly smaller, I believe 2".
I agree those small almost drip drains are a pain.
2024 Artic Fox 3018 5th Wheel
Grand Design 2800BH TT 2021 - for sale
Prior TT 2017 Flagstaff 831CLBSS Classic Ultra lite - SOLD 5/21
TV 2024 F350 DRW - on order
Prior TV 2017 F150 6.5' bed 3.5 Eco-boost Max tow 1800lbs payload
03-23-2021, 03:28 PM
Please provide a pic of that. I've never heard of any Rockwood with this.
03-23-2021, 04:39 PM
You have the same set up as myself. (4 levers, 3 grey & 1 black)
One grey is at the rear and two at center with black tank.
The two grey tanks Do Not Overflow into one another. Nice thought!
My rear grey tank goes only to the outside kitchen sink.
The two grey tanks at center split. One is for the interior kitchen only and the other is for the bathroom sink & shower. The black tank goes to the bathroom toilet, but I understand that is not true in all models. Puzzling!
Good Luck - Stay Safe
Happy Camping
03-23-2021, 10:19 PM
Is that just a sneaky way of calling me a liar ?
03-23-2021, 11:24 PM
Nope, would like to see what changes Rockwood is making since I used to own a Rockwood.
I think Rockwood/Flagstaff make the best trailers for the pricepoint.
03-26-2021, 06:28 PM
We currently have the 8336BH on order and I had asked Forest River about the tanks. Here's their response:
Black 1 (Toilet) - 50 gal
Gray 1 (Shower, Lav) - 50 gal
Gray 2 (Washer) - 40 gal
Galley (Kitchen) - 40 gal
We plan on doing the blade valve trick to combine the washer and bathroom gray tanks for longer trips. A total of 130 gallons of gray capacity is pretty cool even if it's not all one tank.
Tow vehicle: 2020 Ram 2500 6.4 Hemi
Current trailer: 2022 Rockwood Signature Ultra-Light 8336BH
03-26-2021, 06:52 PM
that only works if the tanks drain out a common sewer connection. i'm not sure that all four tanks will drain out a common sewer connection. you need to find out how many actual sewer hose connections you will have and what tank drains into each sewer connection.
03-26-2021, 07:04 PM
Yep - on the 8336BH, the 2 forward gray tanks drain out a common outlet with the black tank. The 3rd gray tank is by itself toward the rear. At least that's what Forest River indicates.
