Old 10-29-2019, 09:54 AM   #1
Nissan Armada as tow vehicle
Anyone out there with a 2017 + Nissan Armada as a tow vehicle? We have a 4x4 Platinum with tow package. Looking for advice on weight distro system(s)/sway reduction. The dealer is going to install one for us, but I want to make sure I'm not getting junk.
Will also be installing a brake control system.
Thanks in advance!
~Mel
medwards7878 is offline   Reply With Quote
Old 10-29-2019, 10:04 AM   #2
007matman's Avatar
Everyone is going to want to know what you're pulling and the associated weights/length.
007matman is offline   Reply With Quote
Old 10-29-2019, 11:36 AM   #3
bikendan's Avatar
And payload capacity number, from the driver's door yellow sticker.
It'll say something like "Occupants and cargo should not exceed xxxxlbs".
Old 10-30-2019, 09:32 AM   #4
trailerdude's Avatar
We tow with a 2018 Armada. A couple things I noticed is the suspension is a little soft, I did a search to see if there were better towing shocks but no one makes them, I was surprised at that. The tall tire sidewalls add to the squishiness so airing them up to close to max helps. We have a Curt WDH with a sway bar but it's just OK. I was looking at the Husky, it looks very much like the Equalizer for a lot cheaper. https://www.amazon.com/gp/product/B0...N209KAZ9&psc=1
2020 Rockwood 2104s towed by 2018 Nissan Armada. Curt WDH with sway, portable 150 watt solar, Home made window evaporative cooler
trailerdude is offline   Reply With Quote
Old 10-30-2019, 12:46 PM   #5
Palinduff's Avatar
A friend tows a big bunk room tt with a 4x2 Armada, bought it the states, probably a 2012 or something. Don’t no weights or anything, but it’s a pretty big unit. They go to The west Kootneys every year with no issues.
2017 F150 XLT 3.5l Eco Boost, SC, 8' Box, 4X4
Max Tow (10 speed, 3:73, 11,700lbs), HD Payload (2440lbs)
2015 Puma 253 FBS
2013 Hyundai Santa Fe
Rad Rover 6 Plus, Tobin Inflatable
Palinduff is offline   Reply With Quote
Old 10-30-2019, 12:56 PM   #6
007matman's Avatar
Either one of the following has occurred..
1) OP realized he's in over his head on the numbers and doesn't want to listen to us regurgitate over and over again that he can't pull this.
2) OP doesn't know the weights and is too embarrassed to admit it
3) found an answer another way.
OP- don't be embarrassed. Many of us were sold more than we can safely tow. You're not the first to be oversold.
Old 10-30-2019, 12:58 PM   #7
CGK
Camping with Labs
You can eliminate sway with a Hensley or ProPride hitch. We have the Hensley and love it - have installed or had it installed on the most recent 3 TTs. We pull with a 3/4 ton Yukon XL with the 8.1 gasser - built to tow, and we are still grateful for the Hensley every day we're on the road. They are expensive and heavy, but really work. Have heard great things about the ProPride, too, but can't speak from experience there. Hensley also sells a quality brake controller. As to how "tow-worthy" that Armada is, would need some additional information to analyze that. Happy camping!
Chris, Paula, & camping Labs, Shasta (RIP 8/10/20) & Cammie
2005 Yukon XL 2500 with 8.1 Engine, Allison Transmission, and 3.73 Axle Ratio
2019 Rockwood Signature 8335BSS with Hensley Arrow Hitch
CGK is offline   Reply With Quote
tow vehicle
