Old 09-02-2010, 03:06 AM   #1
Question No power at all
I have a 2009 Rockwood 5th wheel and it has no power at all. Batteries are good, fuses are good, breakers are good. Its plugged in as well but no power. Is there something I'm missing?
brad644 is offline   Reply With Quote
Old 09-02-2010, 06:28 AM   #2
Herk7769's Avatar
None at all is very unusual.
Do the slides work?
Do the front landing gear work?
Do you have a battery disconnect switch on the battery?
Do you hear a fan from the converter on shore power?
Lets start there.
HAM CALLSIGN - KC3FFW
Old 09-02-2010, 09:16 AM   #3
Iggy's Avatar
NO power to what?
No power to the AC lights and Appliances?
NO power to any DC Battery lights, awning, outside lights?
The common denominator here is the power panel/ convertor panel and not to have either AC or DC power means two problems.
1. The shore power is not reaching the power panel and circuit breakers.
You will need to verify with a volt meter and check the 30 amp circuit breaker to verifiy the power to the panel from shore power.
Now make sure you turn off the circuit breaker then turn it back on as it may be tripped in the mid position.
2. The battery power is not reaching the power panel to distribute thru the glass fuses. How do you know the battery is good? Did you check with a volt meter? What reading did you get?
A little more detail in what you have found would be very helpful.
2012 Georgetown XL - 378TS 73K miles
Life is a journey, not a destination
Old 09-02-2010, 09:25 AM   #4
2Susan's Avatar
I would start back further and make sure the power cord from the house has power. I like the cords with the light at the end - let's you know it actually has power (and helps you find it in the dark).
2011 Georgetown 320DS new June 2010
days camped in 2010: 61
days camped in 2011: 37 (up to Aug 1st)
2Susan is offline   Reply With Quote
Old 09-02-2010, 10:35 AM   #5
Villa Estate 392FLFB
The_Stuff's Avatar
check to see if your trailer has a master disconnect. parents have one in their prowler and they didnt know at first. thought it was just a switch between 12/120
One state/province at a time!
The_Stuff is offline   Reply With Quote
Old 09-02-2010, 12:34 PM   #6
Originally Posted by Iggy View Post
NO power to what?
There was no power comming from the house woops. Thought the batteries were good but they were dead
Old 09-02-2010, 04:14 PM   #7
2Susan's Avatar
I love when it turns out to be something easy!
Like I said I like the extension cords that have a little light glowing at the end. I learned the lesson when the block heater on my car wasn't actually plugged in and the temps were in the mid 30's. Below freezing that is. When I look outside and see the little orange glow it's reassuring.
rockwood
