Old 08-15-2017, 12:20 PM   #21
Glad you got it fixed and thanks for coming back and letting us know what you found.
You're lucky that it was easy to spot.
Gotta go campin!
Old 10-01-2021, 02:41 PM   #22
Originally Posted by Oaklevel View Post
Go back to your tail lights and pull the bulbs first. I have had a bad tail light bulb cause a dead short for the running lights. Also check the tail light wiring.
Good Luck!!
Will 1 bad bulb cause the entire system to not turn on?
jwesley2188 is offline   Reply With Quote
Old 10-01-2021, 02:43 PM   #23
It will if the one bad bulb shorts out and blows the fuse.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 10-01-2021, 04:40 PM   #24
Oaklevel's Avatar
Not normally but it can.
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Oaklevel is online now   Reply With Quote
Old 10-01-2021, 06:07 PM   #25
Chuck_S's Avatar
Light bulbs are already "shorted" inside that sealed glass, that's why the filament glows. When they pop the filament breaks and the light goes out.
-- Chuck
Chuck_S is offline   Reply With Quote
Old 10-01-2021, 07:39 PM   #26
-- Chuck
Obviously you've not seen a drop of water hit a hot bulb, break the glass and the continue to fill the base with water until it shorts and blows the fuse.... or vibration jars the glass loose from the base and bends the filament posts until the positive one touches the base or twist together.
Yes, many bulbs simply burn out... but not all.
light
