Old 05-12-2018, 03:37 PM   #1
No water at kitchen sink, help!!
I am getting my trailer ready for my first after winter trip. I am dewinterizing it, aka flushing the anti-freeze out. I am not getting any water to the kitchen sink. Everything else works fine, any ideas?? I'm going crazy trying to figure it out.
Hope you can help asap! Thanks!!
RD
2016 Rockwood Ultra Lite 2604WS
2018 Dodge Ram 3500 CTD SRW 4x4 Laramie
1993 Jeep Wrangler YJ IL6 4.0 lifted (love it)
Happy Trails All!!
roaddiva is offline   Reply With Quote
Old 05-12-2018, 03:40 PM   #2
cavie's Avatar
remove the aerator from the end of the faucet and clean it out. you pushed water heater crud into it.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 05-12-2018, 03:43 PM   #3
There is no water even getting close to the faucet! Its not the aerator :-( Nothing in my life is that easy......
Happy Trails All!!
Old 05-12-2018, 03:45 PM   #4
cavie's Avatar
How do you know how close the water is?
Old 05-12-2018, 03:51 PM   #5
OMG I am sorry, I misunderstood! It's been a long day.....you were right it was clogged!!!
Thank you!!
Happy Trails All!!
Old 05-12-2018, 03:53 PM   #6
nomad297's Avatar
Unscrew the head from the hose and check inside of the head at the restrictor to see if stuff is in there. While the head is off, turn on the faucet to see if water comes out of the hose.
Bruce
Old 05-12-2018, 03:56 PM   #7
cavie's Avatar
Happens every spring. You are the 3rd one this week.
Old 05-12-2018, 04:29 PM   #8
Flybob's Avatar
This can be caused by opening the low point drains with water in the WH. It will allow the water and crud in the WH to enter the cold water line. Some of it will flow out with the drained water, however some of it will stay in the lines. Net time you charge the system, it will be pushed through and end up clogging a spigot screen. Always drain WH rpior to opening LP drains.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 05-12-2018, 04:45 PM   #9
cavie's Avatar
Thank you!!
go clean the rest of the faucets and the showers.
Old 05-13-2018, 01:49 PM   #10
Maybe it's just me...
Maybe it's just me, but I always remove the aerators BEFORE flushing out the antifreeze, then place a bucket under the tap.
Removing the aerator means I don't have to clean it afterwards.
Filling into a bucket means I can pitch it outside, don't have to flow it into the tank.
Larry
Larry-NC is offline   Reply With Quote
Old 05-14-2018, 09:23 AM   #11
Wolverine 1945's Avatar
Thank you!!
When I de-winterize or flush the system I always start by removing outside shower head,,,and first flushing thru that line !!!
It helps keeping crud from plugging the aerators, Toilet, or shower head !!!
Wolverine 1945 is offline   Reply With Quote
sink, water
