Originally Posted by upser
Is there an available outdoor cooktop for the rockwood 2306? I have a BBQ but would like a cooktop.
I use either an electric induction burner (works well with no heat loss in the gap) or a $12 butane burner (less efficient in wind) in a case from aldi or Sam's club. It works for me and the fuel is cheap and light as well...
I removed the high pressure regulator and connected to the low pressure quick connect system on the trailer and it works fine for my generator and my heater. It was a few bucks in fittings. I have seen others do this with their Webber Q grills as well. I would assume if you used the right parts you could convert a small camping stove to work the same way.
