Old 05-15-2023, 11:56 AM   #1
Outdoor grill propane
Where is the quick connect on a 2701SS?
ID:	287212   Click image for larger version
Frankieatc is offline   Reply With Quote
Old 05-15-2023, 12:08 PM   #2
I didn't have your model but I did have a R/V that had the same hatch.
My kids had a habit of pushing the hose and quick-connect end too far into the hatch when we'd break camp. I either had to use a coat hanger or something to fish it out of the internal compartment or one time I think I had to remove the hatch cover.
Days Camped '19=110 '20=116 '21=123 '22=134 '23=106
Old 05-15-2023, 12:59 PM   #3
Thanks! Heading to camp now.
Old 05-15-2023, 04:14 PM   #4
Took the 3 screws out- but it ain’t going anywhere! Any thoughts?
Old 05-16-2023, 12:47 PM   #5
grege's Avatar
Is there a sealant holding it on? You could try light heat and see if that would loosen it or try getting something under it.
Or
What's on the inside of the camper at that location? Has to be a place where the hose could go like under a seat at a dinette. I'd look to see if you can access the area inside the camper.
'18 Ford F250 Lariat Super Crew
'22 Rockwood 2608BS
Previous '17 Grand Design Imagine 2800BH, '13 Rockwood Roo 21SS
grege is offline   Reply With Quote
Old 05-16-2023, 01:07 PM   #6
bikendan's Avatar
Back then, the quick connect propane line might have been an option. I know some RVs had that white plastic port installed but no propane hose. There would be a nib to have one installed.
Sent from my SM-G781U using Forest River Forums mobile app
Old 06-09-2023, 12:46 PM   #7
It was under dinette. There is no gas flow- could it be clogged by spider webs?
Old 06-09-2023, 12:57 PM   #8
Glad you found it.
It wouldn't be clogged with spider webs if it still has the original quick-connect on the end. They couldn't have gotten in the line as the quick-connect closes off the line when uncoupled.
What are you connecting to? How do you know it has no flow?
Old 06-09-2023, 01:03 PM   #9
Outdoor grill. No flow. Hose connected directly to copper line in frame.
Old 06-09-2023, 07:10 PM   #10
When I took my trailer out on it's first trip I had a no-flow issue too. Turned out the hose had a kink that closed off gas flow and it was in a spot that was hard to see. Took kink out of hose and it's worked perfectly since August 2017.
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 06-09-2023, 07:16 PM   #11
Something to watch as well . . .
Propane pressure from the quick connect is at 11" water . . . It has a regulator from the main tanks to the QC.
If you attach the BBQ to the quick connect with one more regulator the BBQ won't get enough propane to operate correctly.
2012 Rockwood A122, 2017 Kia Sorento 3.3 V6 AWD,
(2012 Subaru Forester with MT (gone to TV heaven))
Cheers and greetings from a Toronto Canuck
Brandoni is offline   Reply With Quote
Old 06-15-2023, 05:43 PM   #12
Here’s how I connected my grill (not my idea). I eliminated my grill regulator.So far so good, I control the heat with the valve.
ID:	288666   Click image for larger version
ID:	288667   Click image for larger version
Camp1 is offline   Reply With Quote
Old 06-26-2023, 07:48 PM   #13
She is working now ��
door, grill, propane
