Old 04-03-2011, 07:23 PM   #1
yvesm's Avatar
Poor Engineering, bent fresh water tank bracket
I was filling my fresh water tank to go dry camping, then I heard this creaking sound and I looked under the camper and something was pushing through the under covering. The brackets that hold the water tank were starting to buckle! I quickly opened the drain and if you look at the pictures you will see the bent bracket. I will contact Forest River about the problem, but I will most likely fix this myself (like all other repairs!).
Name:	bent bracket 1.jpg
ID:	5165   Click image for larger version
Name:	bent bracket 2.jpg
ID:	5166   Click image for larger version
Name:	bent bracket 3.jpg
2013 Prime Time 230 FBS
Days camped in 2013: April to November
Days camped in 2014...about 40
Days camped in 2015...more than 2014!!
yvesm is offline   Reply With Quote
Old 04-03-2011, 07:59 PM   #2
grhodes50's Avatar
Too bad about your problem. If you do fix it yourself, at least you'll know it's done right.
Thanks for posting. You may save someone else a future headache.
Gary & Trish
2019 Nights Camped - 3
Old 04-03-2011, 08:11 PM   #3
yvesm's Avatar
I have done all the repairs on this camper, including major problems. Forest River has sent me any parts that I have needed.
Old 04-03-2011, 08:20 PM   #4
grhodes50's Avatar
Good to hear your able to make the repairs yourself. It's also good to hear that FR has sent you what you need.
Gary & Trish
Old 04-03-2011, 08:47 PM   #5
Make sure the small vent hole next to the filler hole is always pushing out air as you fill the tank with water. If there is a blockage in the vent line and excess water/air cant escape around your filler hose quick enough, you will build hydrolic pressure in the tank which can very easily bend metal brackets or break wood supports. I found that on my unit the vent hose for the water tank was not properly routed, it sagged below the top of the tank and was not pitched to drain back to the tank. What happened was that when I filled the water tank to the top it would force water into the vent line once all the air was pushed out, then this water would create a blockage in the vent line. To add to this problem the filler hose also had a sag in it which would not allow the air to burp out the filler hose. So what was happening in my case was the tank was never really getting filled up all the way once I had a water blockage in the vent. I bent my bracket just like yours when I was filling the tank one day and forgot to shut off the hose and built up to much water/air pressure. The water tank should never have any pressure in it whether it be the air not escaping quickly enough (or at all in my case) or filling with water too fast.
Sticky
Sticky is offline   Reply With Quote
bent
