Originally Posted by Redtickcpa
What the issue is that on shore power i need to get the lithium batteries above 14.4 to "level off" the batteries (per the instructions) to put the batteries in sync other wise when dry camping the batteries reduce at different rates, one will drop to 35% the other is 67%, using shore power seems to fall short, I have 190 watt solar that should kick it up (go power) but it does not seem to get there, i also have a renogy 200 watt suitcase, both have non MPPT controllers so i wonder if upgrading the controllers will help since it will put in more juice quicker.
thanks for your help
something is wrong with your setup if the two batteries are not charging at the same rate. How did you determine each state of charge?
Do not connect more or buy different charging sources
dc-dc or converters etc................ get the batteries equalized first!
Disconnect the solar... for the initial test and charging.
IMPORTANT Charge each battery by itself... until they are fully charged.
with the batteries being so far apart in SOC the current between them will be very high...
the battery BMS could possibly be shutting down the battery because of the imbalance
Disconnect the parallel wiring of the batteries
just use the converter to charge each battery one at a time ,
try not to use any 12v items while charging.
Use a multi meter to confirm voltage as you charge
check each
after BOTH have reach same SOC charged and while reconnecting in parallel .... make sure all connections are clean FLAT and tight .
make sure you have them connected in parallel correctly..
the negative of both batteries joined together and then the positives joined together.
Battery 1 will have the main positive going out to the trailer power center/busbar
Battery 2 will have the main negative going to the frame / busbar
Try not to have a bunch of connections on the Battery terminal
use a busbar to connect other chargers (solar)
battery ---- main Fuse ---- battery disconnect --- Busbar ---- individual wires out to trailer
Connect the solar wires so it is NOT accidentally turned OFF by the battery disconnect
If you are unsure.... of any of your setup take pictures and post them up.
