Not an absorption fridge?
Originally Posted by Superduty glampers
Copy on having things in it. Have you been up on the roof to see if you have warm air coming out of the vent? Could be a circulation issue vent maybe blocked.
Pretty sure the OP's fridge is a 12v compressor fridge, not an absorption fridge. There would be neither a roof vent nor a panel on the outside behind the fridge. It's like a "dorm" fridge except that it operates on 12 Vdc, not 120 Vac.
These were introduced a couple of years ago. Some of them work well and are quite reliable. A few of the copycats are reportedly junk (Furrion). One model appears under at least three different badges including Magic Chef. Not sure about its reputation.
Larry
