06-20-2018, 11:51 AM
Propane Tank Level
I'm new to all this but can anyone suggest how to tell what the level of my propane tanks are? We have Two 20gal tanks and I'm guessing that will last the whole summer but it would be nice to know the levels anyway.
Thanks.
06-20-2018, 12:02 PM
https://www.walmart.com/ip/Camco-RV-...ector/21803283
I've been thinking about picking up a couple of these, but I'm not sure how they would fit in with the switchover valve; and whether theres room in the cover.
Mitch in MN
2018 Patriot (Grey Wolf) 23MK travel trailer
2011 Durango 5.7L and OEM tow package
06-20-2018, 12:07 PM
Just make sure you have both valves open and keep an eye on your auto switchover valve/regulator, when it turns red that means the tank on that side is empty. Pull it off, get it refilled, and then flip the auto switchover valve to point at the tank that wasn't just filled in order to make it the primary tank. Then when that one is empty it will switch to the full tank (Make sure the valve is open) and you can get the now-empty tank refilled without interrupting the propane going into the trailer.
2017 GMC Canyon - CCLB, 4x4, 2.8L Duramax, ARE Z-series shell
2013 Shamrock 21SS
06-20-2018, 12:08 PM
Thanks.
You can weigh them, or pour hot water on the cylinders and run your hand over the tank till you feel the cool temp difference, which will be the liquid propane level.
This thread will explain how to weigh them with bathroom or luggage scales, and see how much is in the cylinders.
http://www.forestriverforums.com/for...ng-133760.html
2011 Flagstaff 831 RLBSS
06-20-2018, 12:10 PM
Here is also another detailed FAQ on the auto changeover valve DieselDrax explained above.
http://www.forestriverforums.com/for...or-146655.html
Since you stated you were new, these as well as some other things are linked to in this thread that may help in your RV adventures.
http://www.forestriverforums.com/for...ts-157524.html
06-20-2018, 12:14 PM
The most accurate way is to weigh them. Stamped on the tank will be the tare weight, often marked TW. That’s the weight of the tank when empty. So weigh the tank and subtract the tare weight. The result will be weight of the remaining propane.
Not quite as accurate, but usually accurate enough: https://smile.amazon.com/Original-Gr...=propane+gauge
And be aware that pressure based gages are not very accurate. The pressure doesn’t really change until the tank is almost empty.
06-20-2018, 12:19 PM
or one of these for almost half price.
https://www.amazon.com/iKKEGOL-Digit...=baggage+scale
2016 F150 XLT 4X4 SCREW 5.0
2014 Grey Wolf 21RR
06-20-2018, 12:24 PM
George & Nancy, Allen, Texas
2015 F350 CC, DRW, LB, Platinum Edition
2018 Cedar Creek 36CK2
06-20-2018, 12:27 PM
Originally Posted by Gsykora
I use those with the app. The monitor is not accurate enough. These are great. This way I can check both tanks yet leave the changeover valve open.....never run out but know when to fill one of the tanks.
It simplifies my life by not having to go open the door and actually check. Such First World problems!!! LOL
FROG AR-0019-242
06-20-2018, 02:05 PM
How to remember which is the primary propane tank
I shut off the propane vales when I am back home and the fridge is unloaded. I made a ring out of some wire that I put over the valve on the primary tank so I know which one I am pulling from. I can't see the pointer on the changeover valve but with the wire ring I know which tank was in use.
2018 Rockwood 2509S Mini Lite
Past: 1984 Road Ranger 20', 1988 Kit Companion
1984 Starcraft 24 foot popup
TV: 1999 Dodge 2500 Cummins 4x4
Honda EU2200i Generator, 300 Watts Solar
Ham Callsign KD7UM
06-20-2018, 02:29 PM
I had thought about getting some of these wireless propane tank gauges.
I have them...I like them a lot.
06-20-2018, 03:01 PM
Trauma Level Check. It is dead-on accurate and simple to use.
https://shop.truma.net/products/truma-levelcheck
Bruce
06-20-2018, 08:15 PM
Originally Posted by nomad297
I was about to get one of those until I found the Bluetooth ones which are more simple and convenient
06-21-2018, 11:44 AM
Thanks everyone for your great comments.
I took the trailer down and had the tanks topped off for the first time. We only used about a fourth of the gas in the two tanks and been camping in it maybe a total of 10 days since we got it. We don't cook a lot in the trailer, just a small breakfast. Sandwich for lunches and dutch oven dinners or out to eat.
The man at the dealer explained the auto switch over and I think I'll just check that each time before leaving. I'm a big Gaget-holic, but I think this will be simplist.
06-21-2018, 11:48 AM
Yep... anyone that understands how the auto-changeover regulator works and knows enough to read the integrated indicator, realizes that's all that is needed.
06-21-2018, 12:58 PM
Originally Posted by MillMitch
I tried these and although they do work they extended my hose to the point that it rubbed on my cover. With the vibration and movement going down the road it eventually wore a hole in the hose and I leaked propane. For some reason safety valve did not stop excessive flow?
You can avoid reality, but you cannot avoid the consequences of avoiding reality – Ayn Rand
06-21-2018, 10:17 PM
Grammar Pedant
Those gauges are a waste of money and a borderline scam.
When you have a propane tank that's full, you have propane that's under pressure to the point of converting it to liquid, hence LPG. Anyway, this is a fixed physical property of propane. On a warm 80 F day, the vapor pressure is 128 psi.
If you have a full tank, the propane vapor above a large volume of liquid propane will have a pressure of 128 psi. If you have a half full tank, the propane vapor above a medium volume of liquid propane will have a pressure of 128 psi. If you have a 1/4 full tank, the propane vapor of a small volume of liquid propane will have a pressure of 128 psi. If you have a tank of one drop of liquid propane, the vapor pressure above that drop will be 128 psi.
When the tank is nearly empty and all of the LPG has converted to gas, then the psi will drop as the gas is used ... but, at that point, there's really nothing left.
Any pressure gauge will be sort of useless until way after it's too late to react.
Good luck.
Former RV: 2018 Rockwood Mini Lite 2504S
06-22-2018, 09:28 AM
My 2019 only has the 524AS Double Stage Low Pressure Regulator with T check valve - so no auto change over or indicator here.
Entry level trailers don't get the good stuff, so that's is why people are looking for propane level indicators, battery shut off switches, voltage monitors, EMS etc.
Mark Duerst
Raleigh NC
2019 Wildwood Xlite 171rbxl
2018 JGC Limited 4x4 w/tow
06-22-2018, 01:14 PM
Just as confused as you
FYI. As mentioned before the gauge that works on the vapor pressure inside the tank is not very accurate. On the large 250 to 1000 gallon tanks you see in rural areas there is an actual float inside that measures the level of liquid propane. This level is transferred to a gauge connected to the outside of the tank by magnets. The gauge can be removed without propane vapor leaking out.
Richard & Jill
06-22-2018, 06:24 PM
The guard I use is sonar based and is based off the amount of liquid. Plus it’s Bluetooth, and I can check while in the camper or the house.
2019 Flagstaff V-Lite 30WFKSV
2021 Chevy Silverado 3500 HD DRW High Country
