Old 05-05-2018, 03:05 PM   #1
Librarianocnj's Avatar
Questions on 2011 Signature Ultra Lite 8312ss
Hi everyone,
I just purchased a 8312ss. Itís in storage now waiting for a bigger truck. Since the battery was dead I plugged the 7 pin into my truck to open the slide outs. Can anyone tell me if there is a battery cut off switch anywhere. And what does this switch do?
Librarianocnj is offline   Reply With Quote
Old 05-05-2018, 07:47 PM   #2
Can't help on your mystery switch, but your battery disconnect switch is probably located under your LP tanks in front of your battery. Most likely looks like this:
On some units your age (like my 2012 Roo 19), they have a push/pull type switch usually located near the power center. Looks like this:
Works like an old car headlight switch: Pull out for on, push in for off.
OR: You simply may not have one.
2011 Traverse LT, 3.6L, FWD
Old 05-05-2018, 08:21 PM   #3
Canadian Member
I have an early 2011 Rockwood Signature TT and it didnít have a battery cutoff from the factory. I installed this Blue Sea M6006 battery cutoff switch on the front of my battery box.
2019 Rockwood Signature 8290BS, Reese Revolution pinbox and B&W Patriot 18K hitch
2011, 8312ss, lite
