Old 03-23-2020, 10:12 AM   #1
Range igniter
The gas range igniter quit working, changed the AA battery but still nothing. Looks like all the wires are attached. Anyone else had this problem?
2020 Rockwood 2104s towed by 2018 Nissan Armada. Curt WDH with sway, portable 100 watt solar, Home made window evaporative cooler
trailerdude is online now   Reply With Quote
Old 03-23-2020, 10:23 AM   #2
KyDan's Avatar
Maybe totally different but our range has the snap push button igniter. It stopped working so I went online and got another from Ebay. Turned out mine was OK but the wires apparently were not heat resistant and they had developed several cracks. This allowed the spark to escape out the cracked insulation and go to ground rather than sparking at the burner.
I replaced the wires and it's been fine the last 2 years.
Check your wires carefully and if they are OK look on Ebay for a replacement igniter. They aren't all that expensive.
Peace!
Dan & Rita D
Blue Ox WD hitch
Camping days 2010-53, 2011-47, 2012-41, 2013-41, 2014-31, 2015-40, 2016-44, 2017-63, 2018-75, 2019-32, 2020-35
KyDan is online now   Reply With Quote
Old 03-23-2020, 10:34 AM   #3
rsdata's Avatar
these work extremely well as replacements and are even portable enough to take outside for the campfire or BBQ... they even get high ratings from amazon
Too much of anything is bad, but too much good whiskey is barely enough.” – Mark Twain
2014 Shamrock 183
Old 03-24-2020, 10:38 AM   #4
The wires look good, there is no spark at all.
Old 03-24-2020, 03:39 PM   #5
Do the stove top igniters spark when you push the button?
If so, make sure that the electrode on the igniter is within about 1/4" of the pilot and that it hasn't slid forward in the mounting bracket. I had to pinch the two hoops on our bracket together some to keep it from moving.
2020 Rockwood Mini Lite 2109S
2017 GMC 2500HD Denali 6.6L
01tundra is offline   Reply With Quote
Old Yesterday, 08:55 AM   #6
mine was DOA when we did the PDI. Dealer replaced it. Speak with your dealer or the manufacturer of the stove about a replacement. By chance, is yours a Suburban 3 burner with oven?
-Jamie
2020 GeoPro 19FBS
2019 Ram 1500
Dupesy is offline   Reply With Quote
Old Yesterday, 10:08 AM   #7
Yes it's the 3 burner. I spoke to the dealer and of course they want me to bring it in. I don't think it's worth the trouble of hauling in 45 minutes away, especially during this time of virus risk. I' m going to try calling the manufacturer on Monday. If that doesn't work I'm thinking of ordering a generic igniter form amazon https://www.amazon.com/gp/product/B0...379VB228&psc=1
Old Yesterday, 10:41 AM   #8
Stupid question, maybe.. Did you put the battery in correctly? I replaced the ignition battery on my Weber grill and put it in backwards...
2016 Siverback 33IK, Towed 30K+ miles
Andersen Ultimate Hitch
Old Yesterday, 11:00 AM   #9
Small difference but...
The gap is designed to be 3/16" on all gas lighting electrodes in the RV.
2019 Forest River Arctic Wolf Cherokee 5thW 285DRL4
2017 Ford F250 W/B&W Companion hitch & Airlift bags
Perseid88 is offline   Reply With Quote
Old Yesterday, 11:10 AM   #10
tried multiple batteries, tried flipping just in case. I think it's dead. Didn't last long, this is a 2020 trailer. I wonder if the more primitive igniter with the knob you turn would be more reliable.
Old Yesterday, 11:16 AM   #11
Try this.. there will be 3 wires coming from the igniter going to each of the 3 burners. They should just unplug if you tug on them. Remove them 1 at a time to ensure 1 of them is not compromised and shorting to ground. They are laying along the bottom of your stove top so if there was a rub through on one or other defect it will short out all of them. Worth a shot..
Also, pay attention to battery install direction.
Old Yesterday, 11:20 AM   #12
Yes, small difference but you wouldn’t expect all of them to all of a sudden be gapped to far away...
