09-11-2019, 01:56 PM
#21
Two options....smaller TT or bigger truck. No-go with the combo you have right now. The TT is heavy and the truck...no offense...a light weight.
09-11-2019, 07:26 PM
#22
I tow a much lighter camper with 3.23 gears. Not the best experience one could have. Jay.
Old Rv 2016 Rockwood 2504s.
Old TV: 2014 Silverado 1500 double cab.
New RV 2020 Jayco 24RBS
New TV 2020 2500HD gas.
09-13-2019, 12:40 PM
#23
Tongue Weight
We have the Flagstaff version of the 2706. Here is a pic of the tongue with two 6 Volts and the WDH and the second pic is the tongue weight, fully loaded, and connected to the truck.
09-29-2019, 04:22 PM
#24
Alright so I have a 2018 2706ws and I decided to get a measurement of my tongue weight so I knew where I was at. Disclaimer I used the DIY method posted by etrailer.com so don’t take these weights as an exact weight but they should be pretty close. So when set up on the scale it read 231lb, I multiplied that by 5 because of the 5ft distance I used between measuring points. If you are unsure of what that means etrailer.com has a diagram to explain it.
That gave me a total of 1155lbs. That is with two six volt batteries at 59lbs a piece and two full 7lb propane tanks at 54lbs a piece. Now dry tongue weight posted for my trailer is 844lbs, not sure if the manufacturer includes propane and batteries on this weight, if anyone knows please let me know. I measured with empty holding tanks, (I have the one grey and the fresh tank in front of the axles), in my front storage is the usual, camping chairs, hoses, wheel chocks and a foldable table, I didn’t weight all those item but probably close to 150lbs, the front bedroom was empty except for bedding. Hope this gives you guys a closer figure on how much tongue weight goes up and quick when you start adding clothes and fresh water to your trailer. I know I was surprised that my tongue weight was that high.
09-29-2019, 04:39 PM
#25
Understand you had one (1) foot distance on the right side and five (5) feet on the left? (The example shows "2 or 3."
That's a lot of weight!
-- Chuck
09-29-2019, 04:48 PM
#26
Originally Posted by S Spackler
That gave me a total of 1155lbs. That is with two six volt batteries at 59lbs a piece and two full 7lb propane tanks at 54lbs a piece. Now dry tongue weight posted for my trailer is 844lbs, not sure if the manufacturer includes propane and batteries on this weight, if anyone knows please let me know. I know I was surprised that my tongue weight was that high.
Manufacturers "dry" tongue weight only includes the weight of full propane tanks, since around 2009. Before that, only empty propane tank weight was included. Battery weight is never included because they are a DEALER-installed item on towables.
Remember that fantasy dry weights are for a stripped-down version of the trailer. Doesn't include the weights of batteries, options(including "forced" options), dealer add-ons, water or cargo.
So actual loaded tongue weights are almost always way higher than the fantasy dry weight number.
09-29-2019, 06:32 PM
#27
-- Chuck
The diagram says 2-3ft I went with 4ft distance between tongue and scale with a total of 5ft between weigh points because my scale only went up to 350 and I was worried it would max out the scale using the 3ft measurement, from what I understand for every foot in between weigh points is what you multiple by. But yeah it is a lot of weight.
09-29-2019, 06:35 PM
#28
Thanks for the clarification, I wasn’t sure what the manufacturer included in tongue weight, kinda of weird they at least don’t include a 12v battery since that seems like a basic necessity.
09-29-2019, 06:52 PM
#29
Problem is that there is no standard weight for a 12v battery.
Which group size, which manufacturer, dual purpose marine or true deep cycle, wet cell or AGM or LiFepo?
All these will cause various weight amounts.
But propane weight is a standard number.
09-30-2019, 07:45 AM
#30
The weight is the ratio between the two legs.
If you have four (4) feet on one side and one (1) foot on the other side the factor is 4x, not 5x so your tongue weight is only 80% of what you posted which is a more reasonable weight but still over 900 pounds.
-- Chuck
