02-28-2021, 12:30 AM
recommendation for a portable quiet generator?
Hi,
Just wanted to know what kind of porable generator are you guys using? How much watts do I need? I'm new to this. I don't know how many watts is needed. Should I get GAS version or Propane? or Dual?
Please advise on what you guys are using and what wattage do I need. I need one that is compact and light weight as my trailer is over the limit
thank you
2021 Geo Pro 20BHS
2020 Tacoma TRD SPORT 4x4
02-28-2021, 12:43 AM
Originally Posted by aboyz
Costco has been selling that generator for years and at a cheaper price. Be aware that it is NOT a Yamaha generator. It has a Yamaha engine but that's it.
And if you want to run the a/c, you'll need a second one or install Micro-Air soft start kit.
02-28-2021, 01:16 AM
If I were to buy a generator, I'd get a Predator 3500 from Harbor Freight. They get great reviews for being quiet, reliable, affordable, and powerful.
2017 Rockwood Windjammer 3006WK
02-28-2021, 02:15 AM
Well....$520 for 1600 watts. Compare those specs to this:
https://www.amazon.com/Pulsar-G2319N.../dp/B00YFT914I
200 watts more for $90 less. It won't run the A/C by itself, though. What are you looking to run with a generator?
02-28-2021, 02:25 AM
Originally Posted by NavyLCDR
I"m looking to run AC. so do I need a higer watts? can someone recommend me one that is portable and light and quiet so I can run AC?
2021 Geo Pro 20BHS
Will this run A/C? A/C meaning the AC outlet?
2021 Geo Pro 20BHS
02-28-2021, 02:26 AM
the reason why I went with the SC200I Yamaha is because I can get it locally for around $300. so that is why I'm asking. its portable and good. But as you stated I cannot run A/C? A/C mean the wall outlet right?
2021 Geo Pro 20BHS
02-28-2021, 02:42 AM
A/C means air conditioner not AC electrical outlets. Again, it depends entirely upon which electrical loads that you want to run to determine how much wattage generator you need. If you want to plug a table light into an AC electrical outlet then you only need a 100 watt generator. I have this generator:
EP2500i, China EP2500i portable inverter generator, 2100W running, 2400W starting Manufacturer & Supplier
It will run my microwave. AC electrical outlets including an electrical heater plugged in. A coffee pot. Run the converter to charge the batteries. Run my refrigerator on AC power. But not all that at once, just one of those high current items at a time (in addition to charging the batteries). It will even barely run my air conditioner at low altitudes.
Mine does not have parallel capability though. Parallel capability allows you to connect 2 inverter generators together to combine their wattage outputs so you can run air conditioning in addition to another large load such as a microwave, refrigerator, heater, etc.
02-28-2021, 02:49 AM
What wattage do I need to run AC?
2021 Geo Pro 20BHS
02-28-2021, 02:54 AM
I was reading online AC in the Geo Pro trailer only uses around 1800 watts. to startup and 650 watts running. If my generator is 2200 watts. I should be good ? no?
2021 Geo Pro 20BHS
02-28-2021, 03:03 AM
My experience with my Geo Pro G17RK with a 13,500 BTU air conditioner was very similar to this with my 2100 watt generator:
https://rvlife.com/air-conditioner-2200-watts/
At 5,000' elevation, though, my generator would not allow the air conditioner to start without tripping offline.
In summary, it is just barely enough generator to start the air conditioner at low altitudes. And don't plan on running any other major electrical load along with the air conditioner.
You can also add a soft-start capacitor to the air conditioner to make it easier to start on a low wattage generator.
02-28-2021, 03:10 AM
thank you so much!! that is what I expected.. the 2200 watts is good enough to run AC.
Now what brand is good? I think the most reliable brand is the Honda 2200i.
But the price is a bit high compare to the Yamaha 2200.
thank you
2021 Geo Pro 20BHS
02-28-2021, 03:35 AM
If it was me and I was going to buy a generator today, this is the one I would get:
https://www.amazon.com/Genkins-Porta...dp/B08JZK3SNJ/
I have had my off brand Chinese generator for two years. It is a bit hard to start, have to pull the cord maybe 20 times when it is cold. But it does everything I want it to.
There will be lots of people that disagree with me, though. But I have been happy.
02-28-2021, 03:42 AM
thank you
I don't think you're reading the post clearly.
NO, it won't run the a/c unless you add a Micro-Air kit as I said in my previous post.
AC-Alternating Current
a/c-air conditioner
02-28-2021, 07:35 AM
Did you all see that Cummins has a portable generator now?
I know some of y'all are going to drop everything to go and buy one..
https://www.electricgeneratorsdirect...xoCaacQAvD_BwE
CW had them in the monthly flyer for just over 1k I think.
02-28-2021, 11:17 AM
Westinghouse iGen 2500
I ended up putting a soft start on my 15k btu air conditioner in my 2205s, and use a Westinghouse iGen 2500 generator from Sam’s Club. The unit weighs under 50 lbs and works great. It always starts within 3 pulls. It run the ac, tv, and satellite tv systems with no issues. Plus, it is pretty quiet.
Kind regards,
Michael
02-28-2021, 11:29 AM
thank you
Keep in mind the Honda has a 121cc engine vs. the 79cc motor in the Yamaha
02-28-2021, 11:45 AM
So the Honda will start the AC with the 121cc engine?
2021 Geo Pro 20BHS
