03-17-2015, 04:23 PM
Refrig GAS light won't stay off
Just went out to the RV to turn on the refrigerator in preparation for camping Thursday (it's a NorCold unit). Set it to 'auto' and RV is plugged in to electricity. After a few seconds, the GAS light comes on and stays on. It's supposed to default to the most efficient power source, i.e. electric. But can't seem to get that darned GAS light to stay off. Have checked the user manual-- no help there. Any ideas?
03-17-2015, 04:34 PM
Is your propane on? if not, put on and see if light goes off. What model of Norcold fridge you have?
Fonzie
03-17-2015, 05:31 PM
Yes, sometimes it takes a few resets to get the brain to figure out what it wants to do. (And, like the Fonz said, make sure the propane is on...if it decides to use propane, no biggy, it doesn't use a whole lot anyway and should switch over to 12V.)
Rick & Karen
(Retired USAF, MSgt)
Monument, Colorado
8-year Travel Trailer RVers
2013 Forest River Rockwood Ultra-Lite 2904SS
2014 Toyota Tundra Maxcrew SR-5 TRD 4x4 (with Firestone airbags in the rear)
03-17-2015, 05:57 PM
Do you have 120 volt going to the unit? If using a Ground Fault outlet at the house is it tripped. If there is no 120 volt at the unit it will go to gas.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
03-17-2015, 06:23 PM
Check the ac power the refrig ispluged into and the refer cb. My bet is it's not seeing 110.
2013 Salem Hemisphere 286 RLT
2009 Silverado 2500HD
03-17-2015, 07:28 PM
Unplugged the RV from the 30-amp plug on my house. Checked ALL the breakers on the RV and flipped each one off and back on. (Even though none were tripped.) We know there is full power to the refrigerator. My friend checked it with his electrical gizmo. For now I've turned on the propane and it's cooling down using that. Well-- the freezer's cooling down-- I don't see any temperature change in the refrigerator portion yet and it's been over a half hour. (Symptom of some other problem???)
03-17-2015, 07:32 PM
Takes at a minimum 12 hours to cool down.
03-17-2015, 07:34 PM
It's a NorCold N611. Am more worried now-- it's been on for awhile and only feel coolness in the freezer, nothing in the lower part. Is that normal?
03-17-2015, 07:41 PM
Perfectly normal operation. As mentioned, it can take a good 8-12 hours to reach temperature (stop opening the door ) and 24 is even better.
03-17-2015, 08:42 PM
Yes, this is normal. The freezer will get cold first and then the fridge. It can take a long period of time, as mentioned in previous posts, to get cold. Opening the door to check isn't helping.
I'm lucky to have a fridge that gets cold pretty fast in about 2-3 hours.
Formerly owned 2011 Salem Cruise Lite 20RBXL & 2011 Toyota Tundra Dbl Cab
03-17-2015, 08:49 PM
Putting dual fans inside the frig and dual fans outside at the bottom of the tubing and above the burner will decrease the cool down time and increase the overall cooling capacity of the unit. When I turn the frig on, I also turn all 4 fans on. I never run the frig without the fans.
03-18-2015, 08:50 AM
Although you've got it cooling on gas now, I haven't heard that you solved your AC problem.
You should check (test and reset) all your GFCI's. The outlet that the fridge AC cord is plugged into (behind the inlet vent panel on the side) is GFCI protected... it may be its own GFCI but more likely to be a downstream-protected outlet off either a kitchen or bathroom GFCI (out previous TT had only one, our new FW has an additional one in the kitchen).
2015 Rockwood Signature UltraLite 8282WS Platinum, GY Marathon LRD, TST 507RV TPMS
2005 GMC 2500HD CCSB D/A, Curt E16, Prodigy P2, Garmin RV760LMT w/BC-20 b/u cam
Self restraint is for the young. I'm old and want it NOW!
03-18-2015, 08:56 AM
Go to this new thread....
http://www.forestriverforums.com/for...use-77367.html
Fonzie
03-18-2015, 09:13 AM
Fraz, what you need to know is that refrigerators are really just freezers, that bleed, or fan assist cold air into the "fridge" portion. Rv dual fuel refrigerators work slighly different, but the principle is the same. The freezer needs to be at spec temperature, before the fridge section can attain its designed temps.
03-18-2015, 11:14 AM
Make sure your Battery switch is on
Scott & Vicki
2018 Silverado 3500HD Dually 6.6L Duramax/Allison
2018 Columbus 366RL 1492 Edition
Camped 2012 19, 2013 110, 2014 129, 2015 97
2016 93, 2017 79, 2018 84, 2019 59, 2020 0,
2021 4 reserved
03-18-2015, 11:16 AM
Won't work on gas without 12v.
03-18-2015, 12:52 PM
If you want it to cool down faster freeze some bottles of water and put them in the fridge. We turn ours on 4 days before a trip with the bottled water. That side of the trailer is in direct sun most of the day and slows it progress.
Retired Fire Dept Battalion Chief
2016 Ever-Lite 232RBS
2012 F150 FX4 W/Max tow & Ecoboost (Best tv ever)
2018 F250 Lariat (ok but I miss my F150)
Getting old ain't for wimps!!!
03-18-2015, 01:09 PM
Yes, they take quite a few hours to get cold...we always park the trailer outside our house the night before heading out in order to both load it up and get the fridge working. (And leave it on gas while driving to keep cold.)
Rick & Karen
Monument, Colorado
