Old 04-26-2017, 08:35 AM   #1
Removing furnace from 2703ws
Has anyone done this? Looks like a pain but I've checked what I can and my fan is not working. Any hints would be appreciated.
2013 Rockwood ultralite 2703ws
2007 Chevy crewcab shortbed duramax
deltadude is offline   Reply With Quote
Old 04-26-2017, 09:05 AM   #2
2703 furnace removal
Taking it out is not to hard, except for laying on the floor to work on it is a pain. If you have the owners manual there is a pretty decent diagram of it for troubleshooting. I had mine out twice for a bad flame sensor,putting it back in is the hard part ,trying to get the air intake and exhaust vent to line up while laying on the floor. It's doable it's just not fun. good luck
South Bend Indiana
Rockwood, 2015 Ultra V 2715vs
05 gmc 2500HD Duramax/Allison
Happy Camper 2715 is offline   Reply With Quote
Old 04-29-2017, 09:33 AM   #3
If anyone is interested, I did get the furnace out. Happy Camper was right. I didn't have a manual but it is pretty straight forward. Luckily I'm fairly small so I was able to get part of me in the area where the furnace sits. Removed the two screws on the front of the heater exposes the two screws holding it down. Removed them. Went outside and removed the plate for the intake and exhaust. One screw holds the intake and six screws removes the plate. Slid the furnace around and used tape to mark the wires for the re-install. Took about 45 minutes.
Old 04-29-2017, 07:36 PM   #4
gooiebob's Avatar
I'm interested. Have wondered how I would get at the furnace if need be. Did you take it completely out or get to the fan just by loosening it?
Bob
2019 Della Terra 29k2s
2014 Toyota Tundra 5.7
gooiebob is offline   Reply With Quote
Old 04-29-2017, 07:40 PM   #5
I took the entire unit out.
Old 04-29-2017, 07:49 PM   #6
TimVWulp's Avatar
I believe suburban warranty is for 2 years.
Below I have a link to the furnace manual Sequence of Operations on page 26.
click the link below down load it give it 15 second to down load and open the link on the bottom of the page
http://www.forestriverforums.com/for...?do=file&id=67
Hope This Helps Tim
TimVWulp is offline   Reply With Quote
Old 08-27-2017, 03:38 PM   #7
Here is my follow up. I took the furnace to a local independent repair shop. He couldn't get it not to work. The day I went to pick it up, he tried again and it wouldn't work. Narrowe'd it down to the mother board. Hardest part about putting it back in was lining up the intake and exhaust.
furnace
