Welcome to the forum, I see it is your 1st post!
The plastic (Coroplast) underbelly is designed to help hold some heat in the bottom of the R/V where the tanks are and help protect some of the underbelly components.
Unfortunately, it really doesn't do a good job for either item.
Some will say it helps keep the "critters" out but that is debatable.
What it does do is add frustration to gaining access to those underbelly components and hides the massive rats nest of wires, plumbing, heat ducts and anything else that is up in there.
If one plans to remove the underbelly, be prepared to spend hours (days?) fastening, re-routing and re-working a lot of things. This is not a bad thing to do and "SHOULD" have been done at the factory but we all know it wasn't.
Days Camped ☼ '19=118 ☼ '20=116 ☼ '21=123 ☼ '22=134 ☼ '23=118☼ '24=101
