Old 04-29-2018, 02:22 PM   #1
Hank/NJ
Rockwood 2304ks stove light and fan
We have a 2018 2304ks. On our first trip things were great. On our second trip we lost all power to the stove fan and light. I checked all fuses and they are fine.
What am I missing ?
Hank Kunz
Rockwood 2304ks
2013 Ford F150
hankyk is offline   Reply With Quote
Old 04-29-2018, 02:36 PM   #2
Jaz 1960's Avatar
I have same camper,I just checked the gfi in bathroom not it.the only thing I see it could be is the 15amp fuse right side last one or reset main.might be sometime else but start there.good luck
Jaz 1960 is offline   Reply With Quote
Old 04-29-2018, 02:49 PM   #3
Hank/NJ
I tried all of those.. still not working. Thanks for checking
Hank Kunz
Rockwood 2304ks
2013 Ford F150
Old 04-29-2018, 04:12 PM   #4
Jaz 1960's Avatar
when you turned on the fan did you open vent outside?
Old 04-29-2018, 04:30 PM   #5
Hank/NJ
no we did not
Hank Kunz
Rockwood 2304ks
2013 Ford F150
Old 04-29-2018, 06:33 PM   #6
Jaz 1960's Avatar
you are supposed to,we were told this from walk thru at dealership ,hopefully didn't fry motor.
Old 04-30-2018, 04:10 PM   #7
I don't have the same camper, but when I upgraded my fan/light assembly I had to remove the stove hood and there was a small rectangular box in series with the +12 volt line. I'm not sure if it is a fuse or a filter (I left it alone while I upgraded), but might be worth a look.
DRiveWell is offline   Reply With Quote
Old 05-01-2018, 10:26 AM   #8
Head Rambler
Your hood fan and light will be 12 volts. If all the fuses test good (not just looks) then you may have a loose wire somewhere. I'd start at the hood and work your way back.
Since this is a 2018 model, If it's still under warranty, I'd contact the dealer and see how long it'll take them to look at it. If you don't want to wait on them and you're pretty handy, you can check several things yourself.
Gotta go campin!
Old 05-01-2018, 10:52 AM   #9
rebeltown's Avatar
Agree with Rambler, test fuses. I've had fuses that look good but test bad...
2017 Rockwood 2304DS Ultralite
2012 F-150 4X4 XLT 5.0 V8
rebeltown is offline   Reply With Quote
Old 05-01-2018, 11:14 AM   #10
RVdoctor
Some times there is an inline fuse inside the the vent housing.
rvdoctor is offline   Reply With Quote
2304, fan, light, rockwood
