03-12-2017, 10:23 PM
Rockwood 2306 table issues
So as far as I can see it is impossible to stand this table and have it flush to the window because of the wheel well. Something has to be missing or I have the wrong table. Can anyone shed any light on this?
03-12-2017, 10:26 PM
Left Coast
Mine is higher then window ledge.
Move the leg.....
03-12-2017, 10:28 PM
Unless there is a special table made for your TT and they put in the wrong one it looks like you may have to move one set of legs in a bit.
Typical limited thought engineering!
2007 Rockwood UltraLite 2603
2006 F350 Lariat Crew Cab Super Duty 6.0 diesel 4X4
03-12-2017, 10:47 PM
Yep, looks like it's not the right table for that model.
Is the trailer used?
03-12-2017, 10:55 PM
Did you try turning it around. I have the same table setup in my microlite. I thought the same thing, then my husband took the table turned it around and it fit. I think one set of legs is screwed in further so it fits over the wheel well.
03-12-2017, 10:56 PM
Sorry, I just looked closer at the legs. They weren't screwed in the right place on one side.
03-12-2017, 11:00 PM
It's a brand new 2017 Rockwood 2306, it has about 6 marks were something was screwed into it but is not there now. I,m thinking it has 2 equal height legs for when it gets used outside if the trailer, and then should have another method of support so it can be used flush up to the exterior wall/window. I just can't see the final design blocks the walkway.
03-12-2017, 11:09 PM
I think the table is from another model that has the dinette in another location.
03-13-2017, 05:56 AM
My '16 has one set of legs offset inward. Will try to get picture tonight (maybe).
03-13-2017, 06:17 AM
Did you get a thorough PDI? This is something the dealer should have already taken care of when you picked up the trailer. It looks like the right table top and legs...they just screwed the legs on the wrong place. Mine are both inward...not on the very edge like yours.
2013 Rockwood Mini-Lite 2306
2011 Ram 2500HD Hemi
03-13-2017, 06:44 AM
My '15 is the same way. You either have the wrong table, or someone installed the legs in the wrong place. One side should be offset inward to allow for the wheel well.
03-13-2017, 09:56 AM
Have screw gun..........Will fix.
03-13-2017, 12:26 PM
Wrong table. Tell your dealer. Doesn't look like you can properly move the legs. On my 2014 2306 we have a totally different table. It has legs that let the table swing/pivot down to the lower position. Probably changed this at some point but your table is not right at all.
There are 10 types of people in the world.
Those that know binary, and those that don't.
2013:31 / 2014:51 / 2015:58 / 2016:37 / 2017:46
2018:16
Total 239
Wrong table?
It looks like the heavy stand-alone table that came with my 2109S model that has a jack-knife couch, not the dinette setup as in 2104.
________________________________________________
2016 2109S Rockwood Mini Lite - - 2014 Chevy Silverado Texas Edition
03-13-2017, 01:29 PM
Look at pics #25 and #26 in the link below. The outer legs by the window are clearly NOT at the end of the table, like the inside set is. You probably just need to turn the plate that the outside set is attached to by 180 degrees, but you'd need to measure the offset that you need to make sure. You MIGHT have to not only turn it around but move it more toward the center of the table.
#R201717209 - 2017 Forest River Rockwood Mini Lite 2306 for sale in Bridgeview IL - House of Camping
Unless my dealer were close by, I'd fix it myself.
UPDATE: I just had a second thought:
If you just spin the plate around, the legs will want to fold to the outside rather than the inside. So you probably really need to just move entire plate inward an appropriate distance. I'm not sure how well they will fold up with the other set of legs if you do this. Make sure you try folding them before you run any screws into it. But I would assume the "correct" ones fold OK.
2011 Traverse LT, 3.6L, FWD
03-13-2017, 04:23 PM
A bit off topic, but has anyone found a way to travel without folding the table down? I find that a nuisance.
03-13-2017, 04:31 PM
Spending 42 seconds, at the most, to collapse and place the table is too much? I'm curious.
Do you plan on having things on the table while moving?
I'm baffled.
2011 Nissan Xterra V6
2016 Rockwood MiniLite 2306
Nights Camped 2016 [24]
Nights Camped 2017 [63]
Nights Camped 2018 [27]
03-13-2017, 04:32 PM
Looking at the pictures, I think I'd rather have a wall mount for internal use leaving one leg strapped up. Moving the leg in might make it unstable to use outside and may make folding the legs impossible because of overlap.
2013 Salem Hemisphere 286 RLT
2009 Silverado 2500HD
03-13-2017, 04:39 PM
Ah-ha. I see something that may resolve this. In the photo I see something in the middle of the window lower frame that I don't have in my 2306. It just might be a support for the table if you fold one set of legs up. That might be the solution. Fold up the outside let of legs and support the table on that thing below the window. That just maybe a part of the window since my windows are different and I don't know what that thing is. Just a thought.
2018:16
Total 239
Who Dares, Wins
Had the same setup on our 2306. One leg was offset (flipped around from your pic) it was still a bit off the wall.
As for leaving it up, did it one time by accident and it busted up the legs. We made it work then switched to the post style poles and never put it down again.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
