Old 07-05-2022, 10:20 PM   #1
Rockwood 2604ws smell when flushing black tank
I have a 2019 Rockwood 2604ws. When I flush my black tank there is a strong urine smell in the bathroom. There is no wetness in the floor, but I canít find the source of the smell. The smell goes away in a few days and if I donít flush the tank there is not a problem.
Any ideas where m/how to look?
Thank you,
Steve.
Srockey is offline   Reply With Quote
Old 07-05-2022, 10:29 PM   #2
What is the make and model number of that toilet?
2015 Dynamax REV 24TB class C
Reverse_snowbird is online now   Reply With Quote
Old 07-06-2022, 05:02 AM   #3
make sure your drain valve is closed. walmart sells this orange liquid. pour about 2oz in toilet. add plenty of water.
Abe Arctic Wolf 2021 29IRl
2017 Titan XD 5.0 Diesel 2018 Indian Roadmaster
Disabled Vet, IT Guy SW Fla.
wildmanabe is offline   Reply With Quote
Old 07-06-2022, 11:31 AM   #4
njfishing's Avatar
Not sure what brand and model of toilet you have but I had a dometic and the ball seal in the toilet got unseated when I stuck a cleaning wand down there. This allowed the black tank vapors to escape into the bath room. One sure way to tell is to fill it with water and it should remain full and not drain down. If it drains down the ball is not seated correctly. If the water stays in it next place I would look is the wax ring between the toilet and the floor.
Lastly there was a series of dometic 300 series which had some issues with urine odors to the extent where they offered to send replacements free of charge. https://www.forestriverforums.com/fo...or-170420.html
Gerry Z
2018 Forest River Heritage Glen 272RL
2018 Ford F150 Lariat 3.5 Ecoboost Max Trailer Package
Curt Trutrack WDH
HD Roadmaster Active Suspension
3200 Firman Generator/Inverter
njfishing is online now   Reply With Quote
Old 07-06-2022, 11:48 AM   #5
Flybob's Avatar
Do you have the dump valve fully open when you flush? Also check to insure the vent pipe has not slid down further into the black tank. You can do this by looking into the vent on the roof.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 07-06-2022, 11:50 AM   #6
Chuck_S's Avatar
Solution:
if I don’t flush the tank there is not a problem.
Flushing the black tank is rarely required unless you're poisoning it.
-- Chuck
Chuck_S is offline   Reply With Quote
Old 07-06-2022, 03:19 PM   #7
It is a Dometic. Not sure if the model. Where do I find the model number.
Old 07-06-2022, 03:51 PM   #8
Part-Time Campground Host
cboss's Avatar
If it's plastic it's a 300. If it's porcelain it's a 310 or 320. The 320 has a larger oval bowl. I'm betting you have a 300 because of your model and year. The 310 is plug and play with the 300, we love ours.
Craig & Cath
Days camped since 2015(retirement): 1272
cboss is offline   Reply With Quote
Old 07-06-2022, 08:14 PM   #9
Dometic 300
Specifically, the bowl of the 300 had an inside and outside layer manufactured separately. When they were fit together, urine could escape and pool between the layers. This could not be fixed.
Originally Dometic gave free replacements, then $75 coupons. I'm not sure they're even doing that any more.
Larry
Larry-NC is offline   Reply With Quote
Old 07-17-2022, 12:32 AM   #10
Croaker's Avatar
The seal leaks poopy water into the hollow space in the cheap plastic toilet.
I got a porcelain toilet and we couldnít be more happy with the new toilet.
Croaker is offline   Reply With Quote
Old 07-17-2022, 01:20 PM   #11
New here, old elsewhere
lwbfl's Avatar
Originally Posted by Chuck_S View Post
Solution: Flushing the black tank is rarely required unless you're poisoning it.
-- Chuck
I have to flush mine every time just to reset the level indicators.
2021 Coachmen Apex Ultra Lite 253RLS
2016 Silverado 1500 Crew Cab Z71 / 6spd / 3.73
lwbfl is offline   Reply With Quote
Old 07-17-2022, 01:47 PM   #12
Chuck_S's Avatar
This will depend on what sensors are in the tank. But I'd try an enzyme and Odorlos in the black holding tank and save the labor if that works. Horst Miracle Probe sensors work for me and were a direct replacement for the bolts thru the tank wall that claimed to be sensors in the OEM tank.
Seems we have two "stinkies" present here with the toilet being fixed only by replacing it. I'll have to inspect what I have but don't recall any smell.
-- Chuck
Old 07-17-2022, 02:54 PM   #13
lwbfl's Avatar
-- Chuck
Just in regards to my statement, I have no smells. I also don't consider attaching a water hose while I dump to be work at all. Just rinses off the sensors so they work on the next trip.
Old 07-17-2022, 06:17 PM   #14
Chuck_S's Avatar
I don't mind anyone wasting their own time with unnecessary tasks like this -- as long as they're not in front of me at the dump site. Actual dumping should take no more than 5 minutes from spotting the camper to pulling away. That requires preparation before stopping at the drains -- I've seen guys searching for their sewer hose for several minutes after they sat in line for several minutes while the guy before them did several rinses and made sure to put everything away before he pulled away. These are the same guys who block the gas pumps while they go into to get drinks and snacks...
On a full service site? Spend as much time as you want.
-- Chuck
Old 07-17-2022, 07:37 PM   #15
lwbfl's Avatar
-- Chuck
It doesn't take any more time to hook up a hose to the flush port. You'd have be one of those people who can only do one thing at a time if it takes additional time to screw in a hose and turn it on as the tanks drain. Mine is done before the gray tank can finish draining. Some of us like to start with a clean holding tank and working indicators. All sorts of folks have RVs these days, even ones who complain about things have have zero effect on them.
Old 07-18-2022, 12:44 AM   #16
Check your black tank flush vacuum breaker…mine leaked right off the hop, brand new trailer. I replaced it (plastic) with a commercial grade brass one - no issues since with any drips or leaking. I did however have an odor when running the bathroom fan…tracked it down to the same valve…which I had blew the line out to winterize but hadn’t used it yet this season. The fan was pulling black tank odor through the black tank flush line…easy fix though. Ran some water through the line.
JohnnyPop is offline   Reply With Quote
Old 08-03-2022, 05:46 PM   #17
Go Pak
unyalli's Avatar
Maybe try this? https://www.amazon.com/Happy-Campers.../dp/B005XEFADU
2023 Rockwood Ultralite 5th 2622RK
2015 F150 Lariat 4x4 CC Ecoboost 3.5L
unyalli is offline   Reply With Quote
2604, black, black tank, flush, rockwood, tank
