thanks for the feedback...here are some testing feedback:
First photo) the LEFT switch controls the light, right above it, but ONLY if the light's own switch is left in the 'ON' position. Good to know.
For the RIGHT switch, it controls the 'small' outside light, right at the top left of the entry door. Also good to know : ) (but, what's confusing is that there is also another large round 'scare' light, on the OTHER side of the outside entry, controlled by the 'Right' switch under the Sink's upper cabinet! Weird placement.
Second photo) the LEFT switch, the other one now in question under the sink's upper cabinet....AHAA! I think I've figured this one out: O.k. since those first two switches in question controlled 'lights', with two of them 'outside' lights, I decided that just maybe there is ANOTHER outside light I didn't even think of.... one that is right at the front left of the hitch! But, while this one would 'seem' to be something to do with the 'trailer' aspect of the RV, while towing, it's actually another 'outdoor' light that you can turn on with the LEFT switch, above the sink. Now, 'why' that light is there is another story - maybe so you can illuminate the 'front' of the RV is company is stopping by, along with the large 'scare' light AND the entry light? Probably. The reason I haven't seen this light come 'ON' is because it has no bulb, not even a cover.... down to the auto parts store for a bulb! Thanks for helping 'lead' me to this discovery : )
(by the way, yes, it would make some sense that a 'Water Pump' switch might be located here, after all, if you are off-grid and need water at the sink it would be the 'prime' place to locate one, right? No. It's not. The only Water Pump switch is at the entry door, part of the 'Micro Monitor' for the tank readings.. Go figure.
Third) the RIGHT side switch in the bathroom works both the ceiling RV light, if left in the ON position, the above-sink light bar, IF left in the ON position, AND the Fantastic Fan, IF left in the ON(1,2,3) setting AND the vent is left OPEN, BUT, the LEFT side switch is still in QUESTION...
Again, another place that you might think would be a convenient place for a second Water Pump switch, but NO, it's not.
Wouldn't you know it, there's ANOTHER large round 'Scare' light on the OPPOSITE side of the RV, which you'd never see, and the light had a burnt bulb! Crazy, but now we know!
all these are 'figured out' now...thanks for you prompting me to go to greater length in 'testing' what they operate - now, though, I might just want to 'switch' some of these switches since the 'side' they are on is not conducive to what you might 'think' they control!
See ya in the funny papers! : )
The Turners...
