Originally Posted by LSchmitz
The brochure states that the 8329SB GVW (dry weight plus carrying capacity) maxes out at about 11,000. That said, the Ford 150-3.5L EcoBoost twin-turbo V6, at 375 horsepower and 470 lb-ft. of torque states that it has a tow rating of 13,200 lbs. But I have read in other threads that the 1/2 ton is not good enough. Thoughts?
My question: Exactly
WHAT says tow rating of 13,200 lbs? I'm guessing you're reading some pie-in-the-sky brochure which almost always uses the maximum for the model.
My 2009 Silverado owners manual lists 99 (yeah, ninety-nine!) different permutations (engine size, bed size, transmission, HD cooling, etc) that range from 4,000 lb to 12,000 lbs towing. My 2016 Owners Manual still lists 54 permutations for the 1/2 ton.
And if an RV salesman doesn't ask the same question about YOUR model truck, you know he's just trying to sell you the trailer; he doesn't give a @##$ about your safety.
SO - not all 1/2 tons are created equal and you need to know the specs on YOUR exact version. And you also need to look on your drivers door frame for the payload number, because most sources (VIN searches included) only seem to list the maximum.
I suspect you're going to be unpleasantly surprised.
I know I'd never pull that trailer with a 1/2 ton.
