Old 03-09-2017, 05:39 PM   #1
Rockwood entertainment issues
I have a tv installed in my bedroom with a coax I put and another outside. How do I get what's playing through the sound system (i.e dvd) to play through to the rooms?
schwim15 is offline   Reply With Quote
Old 03-09-2017, 06:07 PM   #2
If you want better help, I would suggest you provide the year, make and model number of your TT. Also the model number of your entertainment equipment.
2011 Traverse LT, 3.6L, FWD
Old 03-09-2017, 06:34 PM   #3
For DVD and sound system they would need to be connected with RCA jacks and or HDMI cable.
2015 2819VS,
2011 Tundra Supercrew
bruin is offline   Reply With Quote
Old 03-09-2017, 07:08 PM   #4
It's a 2106 2608ws. Irv66 entertainment system. So does an hdmi cable need to be fed through from the irv to the other tv? Because I don't think that's possible. Maybe I can split the coax signal?
Old 03-09-2017, 07:26 PM   #5
I don't care of I have to watch it over coax....I just need to figure out how to get the dvd to play OVER the coax.
Old 03-09-2017, 07:34 PM   #6
We gave up on running cables in our Rockwood. However we did buy a small Blueray player that is easy to move outside to watch a movie. We found that we have more Blueray discs and the IRV66 was only DVD. I don't believe the IRV has coax output.
2015 2819VS,
Old 03-09-2017, 07:37 PM   #7
But coax runs into each tv.....I assume it's going through the receiver. ....would like to have sound go through speakers....I mean isn't that the point in having speakers in bedroom and outside?
Old 03-09-2017, 08:05 PM   #8
The coax does not go to IRV. There is a coax audio in on the IRV but I do not know the purpose of it. There are multiple HDMI outs. Because the only 5.1 is in main area that is where we watch our movies. I think the additional speakers are so you can listen to music everywhere. To improve audio we changed out sub in trailer. The one in trailer is a box with a speaker.
2015 2819VS,
Old 03-09-2017, 08:29 PM   #9
Crap i accidently unsubscribed from this...how do I 're-subscribe'? Also how do you hook up an extra speaker (sound bar) do the units have extra speaker outs for this? How do I get to them everything is sealed
Old 03-10-2017, 04:00 PM   #10
I haven't used a sound bar but generally they would hook up to TV with various types of cables. Maybe someone on forum has hooked up sound bar to IRV66. I connect my TV with HDMI cable to arc connect on IRV66. I've pulled the IRV66 out from wall and fished wires behind panel. Not to hard to fish cables and pull out IRV. IRV uses a flat connector for speaker wires. Where do they hide the sub woofer in your trailer?
2015 2819VS,
Old 03-10-2017, 04:58 PM   #11
hmmmmm? Theres a subwoofer? I might have to investigate. There is one cabinet that is 'screwed' shut....wasnt aware they had subs.
entertainment, rockwood
