Old 07-21-2018, 02:47 PM   #1
Rockwood front and rear doors keyed alike?
I have a 2014 2502S mini lite. Front door lock and deadbolt open/close fine. But, when trying the same key, it goes in fine , but won't turn. I've lubed the locks, but still won't turn. Any advise would be appreciated.
Dueeast is offline   Reply With Quote
Old 07-21-2018, 02:52 PM   #2
Check you key numbers. Many TT have different keying for the front and rear doors. My Microlite has different keying: front and back doors.
Larry WB4WSA
2017 Microlite 25KS
2006 F350 SD CC 6.0
wlstroud is offline   Reply With Quote
Old 07-21-2018, 05:23 PM   #3
Two keys on the 2604ws. One of the reasons I went to a RVLock.
Rockwood 2604WS
Ford F250 Diesel
Blue Ox Sway Pro
allenb12 is offline   Reply With Quote
Old 07-21-2018, 05:29 PM   #4
SeaDog's Avatar
My rig with two doors has two keys, its called assembly line for speed.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 07-21-2018, 08:30 PM   #5
My Mini Lite had front and rear keyed differently. I picked one and got a new matching lock for the other one.
http://www.rvlocksandmore.com/
2011 Traverse LT, 3.6L, FWD
Old 07-21-2018, 08:52 PM   #6
Took me a few tries to figure it out, but YES, we have two sets if keys, one for the front door and one for the back door.
Bigg Kahunaa is offline   Reply With Quote
Old 07-21-2018, 09:16 PM   #7
When I had my PDI, the dealer wrapped some tape around one of the keys so you could tell them apart. But you still had to carry two keys. Single key is a LOT easier.
Old 07-22-2018, 09:00 AM   #8
our front and rear doors were keyed differently. get the lock / key code from the lock that works and then order a new lock with the same key code for the other door. we used rvlocksandmore.com but there are other places on-line. not hard at all to replace the lock.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is offline   Reply With Quote
Old 07-22-2018, 01:32 PM   #9
B and B's Avatar
If you have two keys and one breaks you can still get into the other door. Seems like a good design on this part.
Old 07-22-2018, 02:14 PM   #10
And...
And if you have two keys alike and one breaks, you can use the other one to get into both doors.
Larry
Larry-NC is offline   Reply With Quote
Old 07-22-2018, 05:43 PM   #11
Larry
You also have 4 keys, not just 2!
Old 07-22-2018, 06:03 PM   #12
n0ms's Avatar
A locksmith can fix this.
Plan 2 order two new key ways that are the same number as the other door.
Youtube will show you how to make a majic key. You file one of the old keys in a spot. When you put the old key that you made majic, in the key way that is unlocked, the key way come out. You then push the new key way in the old hole.
n0ms is offline   Reply With Quote
Old 07-23-2018, 12:09 PM   #13
Tundra 2014
locks
I have 5 keyed doors or storage, all different keys.
Tundra 2014 is offline   Reply With Quote
Old 08-30-2018, 01:31 PM   #14
Problem solved
Took rear door latch apart from inside, there was a sticker with the key code #, found them on eBay new two for $9.95
Old 09-03-2018, 08:19 PM   #15
WoodLark-SC's Avatar
RVLocksAndMore | RV Locks | RV Keys | Fastec FIC Locks and Keys
How did you order a lock with a specific key code?
2013 Ram 1500 CC 4WD
2019 Rockwood 2503s
WoodLark-SC is offline   Reply With Quote
Old 09-03-2018, 09:56 PM   #16
Your key and lock should have a code on it. You can order a lock with the same code here:
Old 09-08-2018, 02:41 PM   #17
Thanks to your info, I ordered, received, and installed a new lock on one of my doors.
If anyone needs a lock with "G383" key code let me know. I have a spare I'll sell cheap.
2019 Rockwood 2503s
door, rockwood
