Originally Posted by kkelly
I am getting my rig ready for camping. I have a large slide that has the two rails underneath that each run on a gear. What do I use to lubricate or maintain the slide running mechanisms. I have used spray on the rails and am asking if I should put some lithium grease on the gears.
I'd avoid any grease as it will trap any road grit in it and possibly impair operation.
I use a lube labeled specifically for slide mechanisms. A "dry lube". Lots of these on the market and when my can runs out i'll just go with a generic. I give my slide mechanism a spray coating about twice per year.
Can't say it's magic but I haven't had a single hesitation or chatter in 3 years since i brought trailer home.
2023 f-150 SCREW XLT 3.5 Ecoboost (The result of a $68,000 oil change
