Old 11-18-2017, 11:31 AM   #1
rockwood thermostat
Have a early 2017 rockwood 8328bs with a analog thermostat. Will a digital one work better?
hcamper is offline   Reply With Quote
Old 11-18-2017, 11:52 AM   #2
bikendan's Avatar
Yes
I surprised that a 2017 Rockwooddoesn't have a digital thermostat.
Old 11-18-2017, 12:39 PM   #3
I replaced our 2017 Windjammer analog thermostat with the digital version. Direct replacement, even uses the same screw holes, and wire colors. Very simple job. Digital thermostat works great, I just wish it was back-lit. I found for about $60 on Amazon.
2017 Rockwood Windjammer 3006WK
dankirk is offline   Reply With Quote
Old 11-18-2017, 12:54 PM   #4
I installed the same one. The top screw on mine was a little lower.
My only complaint is that it's not back lit, other than that, works like a charm.
2017 Rockwood MiniLite 2506S
2022 F250 7.3/4.30
bshort is offline   Reply With Quote
Old 11-18-2017, 01:13 PM   #5
WFD
x2....I did exactly what Dankirk mentions on our last 2 trailers...very easy fix, and exactly as dankirk mentions. Got both mine on amazon as well. It can be had in white if you prefer it that way...One thing I did after a suggestion from someone on the forum here...once you remove the old stat, the hole in the wall can be quite big, so secure the wires somehow so you don't lose any into the hole. Also, because the walls are so thin on these trailers, you can get hot or cold air trapped in the walls that can be several degrees different than the ambient temp that the stat is reading in the air. So before putting the new stat on the wall, I filled the hole with a bit of fiberglass insulation so that the thermostat only reads from the ambient air and not from trapped air that can be coming from the wall, leading to the stat getting an inaccurate reading.
Added bonus to the digital stat is that it has a 1 degree variance from your set temperature point as opposed to the 3 or more that the analog one has. This is probably the best mod I made on our last 2 units.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 11-18-2017, 01:17 PM   #6
I installed the digital Coleman Mach. It controls better but it reads about 4 degrees high.
2017 Rockwood 2703WS - Sold
2015 Keystone Sprinter 333FWFLS
2017 F250, 6.2 Gas, 3.73 Axle, 2902 lb Payload
If women don't find you handsome, at least they should find you handy!
andymil is offline   Reply With Quote
Old 11-18-2017, 04:06 PM   #7
Just replaced mine today
I just replaced mine with the digital version today. Perfect fit, and the wires are the same. I read a lot of threads about replacing the analog version with Honeywell home thermostats, but this one looked like a no-brainer. And it was. Took about 30 minutes to install and test. I like no-brainers. And there was no bloodshed as there is usually with anything I try to do
Skypilot54 is offline   Reply With Quote
Old 11-18-2017, 04:08 PM   #8
Jack's Mini 2304ks
rockwood thermostat
I wanted one with large numbers that was also backlit.Click image for larger version
jjmffca is offline   Reply With Quote
Old 11-18-2017, 04:47 PM   #9
No bloodshed??? Must be time to celebrate!
Old 11-18-2017, 06:54 PM   #10
RangeMaggotBob's Avatar
I did the exact same thing. You can't get any easier. If you really take your time, it may take 10-15 minutes to complete the job...
2015 Forest River Rockwood Signature Series Ultra Lite 8289WS w/Diamond pkg.
2014 RAM CTD 6.7 Tradesman 4WD Auto Crew Cab Long Bed
Honda eu2200i generators
RangeMaggotBob is offline   Reply With Quote
Old 11-18-2017, 07:21 PM   #11
DavidBo's Avatar
I also replaced my cruddy analog 'stat with the upgraded digital version. Spliced the wires easily enough, but the original unit was mounted with a single screw in the middle secured to a wall "stud". The screws in the actual side mount holes were just for show. There was no center hole in the new thermostat, so I used a couple of really shallow molly anchors in the standard location which made a nice, secure installation.
The digital unit does a much better job of maintaining a steady temperature with the A/C. Easily worth the cost and effort.
DavidBo is offline   Reply With Quote
Old 11-18-2017, 08:56 PM   #12
SailorSam20500's Avatar
Another happy owner of the digital version. Easy install, did fill the hole with insulation. Works a lot better. Used blue crimp connectors.
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
SailorSam20500 is offline   Reply With Quote
Old 11-19-2017, 11:28 AM   #13
Digital version is great. Holds the temp much better. Set it on 70 and as soon as it hits 72 the ac turns on. Use to be 74 on the old one. Nice, easy upgrade.
rcguy is offline   Reply With Quote
Old 11-19-2017, 11:38 AM   #14
rebeltown's Avatar
See above about insulating.
2017 Rockwood 2304DS Ultralite
2012 F-150 4X4 XLT 5.0 V8
rebeltown is offline   Reply With Quote
Old 11-19-2017, 05:50 PM   #15
Hclarkx's Avatar
I like my RVcomfort digital tstat as well however it does have one downside. Because it holds temp very tightly, the furnace cycles quite frequently when it is cold out. My three season 5th wheel cools off fairly quickly and my furnace heats quickly, hence the frequent cycling with a small deadband in the tstat. The frequent cycling is a nuisance and frequent cycling of the furnace reduces efficiency. Likewise for the a/c on a hot day.
This was less of a problem before I bypassed the lossy and leaking heat ducts and now get twice the heat from the furnace.
2020 GMC Denali 2500HD Crew 4X4 Gas 6.6L
2015 30' 8280WS Rockwood Ultra Lite
Solar, LiFePO4, 12V fridge, mini split
100% dry camping and boondocking.
https://hclarkx.slickpic.com/gallery/?viewer
Hclarkx is offline   Reply With Quote
Old 11-19-2017, 06:13 PM   #16
are the digital ones more accurate then the analog ones?
Old 11-19-2017, 06:20 PM   #17
Yes. The analog can have a 3-5 degree swing on either side of the set. I swapped out to the the Coleman Mach digital several months ago and it will hold 1-2 degrees on either side of the set temp.
I love it and it was a 15 minute job.
Marty
2016 Rockwood 2703WS Sapphire
2016 F250 SD 6.2L
Martsing is offline   Reply With Quote
roo, thermostat
