Old 05-04-2018, 11:48 AM   #1
Ejs4029's Avatar
Rockwood Ultra Lite Jskirt ?
I have a 2016 Rockwood Ultra Lite 2703 Does any one happen to know the width of the J skirting ? I think other Rockwood models use the same J skirting...My trailer is in storage so I don't have access to it right now.
I'm working with a dealer on getting a piece that was damaged and they said it comes in two widths 9" or 12 7/8's not sure which I need.
2015 Ram 2500 CTD,CC,SB,4x4
2016 Rockwood 2703 Emerald Edition
Husky CenterLine TS Hitch
TST 507 TPMS
Progressive Industries EMS-PT30C
Ejs4029 is offline   Reply With Quote
Old 05-04-2018, 05:15 PM   #2
I have a 2604WS and just replaced the section behind the rear door. I did not measure it but it was not almost 13" wide. So probably 9". My local dealer had it in stock in white. He had the paint matched and painted the entire side. Looks like new.
Rockwood 2604WS
Ford F250 Diesel
Blue Ox Sway Pro
allenb12 is offline   Reply With Quote
Old 05-04-2018, 08:15 PM   #3
Looking at his wheels and assuming they are 14 or 15 inch, I would agree that his skirt is probably 9". If it was almost 13", it would be almost as wide as his wheels.
2011 Traverse LT, 3.6L, FWD
Old 05-07-2018, 09:10 AM   #4
Ejs4029's Avatar
Unless I'm doing the measurement wrong mine width is wider then 9" and closer to 13" from the top where it goes in the top of the molding to the end of the curve in J part.
TST 507 TPMS
Old 05-07-2018, 12:16 PM   #5
The skirt on my 2018 2706WS is just shy of 13 inches. Sounds like it is the same as yours.
Ken
2018 Rockwood 2706WS
2007 Ford F-350
rvee-nut is offline   Reply With Quote
Old 05-07-2018, 12:20 PM   #6
Ejs4029's Avatar
Ken
Thanks rvee-nut for checking on the measurement...I appreciate it
TST 507 TPMS
Old 05-07-2018, 01:36 PM   #7
Just as confused as you
Scrapper's Avatar
Hey, guys. How much work is involved in taking the J- skirt loose? I need to gain access inside a 8' section to repair the wires for the step light and I hope one side marker light. Either mice or chipmunks had a party. The only place I can figure they got in was through the opening for the crank to manually operate the slide.
I took a stopper for a old style sink and cut it for a wall anchor to fit, threw it in the freezer so I could drill a hole for the screw to draw it up tight.
Name:	Chewed Wires.jpg
ID:	170996   Click image for larger version
Name:	Manual Crank Hole.jpg
ID:	170997   Click image for larger version
ID:	170998   Click image for larger version
ID:	170999   Click image for larger version
Name:	Stopper Installed.jpg
Richard & Jill
Camping since 1989, seasonal since 2000
The Faster I Go, The Behinder I Get.
lite, rockwood
