Old 05-27-2018, 08:08 AM   #1
Rockwood ultralite
Have 2013 Rockwood Ultralite. Wondering where the antenna power booster is located if I have one and also have switch under overhead cabinet to left of front door as you enter. Can not figure out what this switch does. Any help out there?
rgood is offline   Reply With Quote
Old 05-27-2018, 08:37 AM   #2
Rockwood ultralite
I have a 2017. The switch on mine where you are describing turns the awning led lights on
Rdeejr is offline   Reply With Quote
Old 05-27-2018, 11:51 AM   #3
Thanks. I donít have awning lights but there is wiring for them and it makes since.
Old 05-27-2018, 11:57 AM   #4
Not to bother you again but when I looked not sure how they would plug in, if I had them. I can see the wiring down the awning arm.
Old 05-27-2018, 05:14 PM   #5
Assuming you have the usual crank up Winegard antenna, you should have a wall plate where the antenna cable from your TV plugs into the wall. Looks like this:
The little button on the right turns the booster on and off; there's an LED that lights when it's on. (Note: The booster is actually in the antenna, this just turns it on and off.)
I've attached a manual for it.
2011 Traverse LT, 3.6L, FWD
Old 05-28-2018, 06:11 AM   #6
I have the wall plate but nothing is plugged into it yet tv works. I donít know.
Old 05-28-2018, 07:20 AM   #7
XenoRev's Avatar
You have to have the power on for the antenna to work. The amplifier passes very little si gnal without power.
2018 Salem 27DBK
2004 Ram Quad 1500
Days past:1996 Coachman Capri-Ruby Ed. 27DS
1995 GMC Yukon Sport
1986 Jayco1016PUP
Days Camped:'13-10 '14-20 '15-6 '16-9 '17-14 '18-3
XenoRev is offline   Reply With Quote
Old 05-28-2018, 07:22 AM   #8
fonzie's Avatar
That is because TV is connected in the back of the plate.
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 05-28-2018, 09:08 AM   #9
Thank you so much. I thought that was the reason as all of the wiring goes through the wall. Older but fairly new to RVing but love it. Still learning .
Old 05-28-2018, 09:26 AM   #10
I suspect you have a power awning? And the wires you see are for it? just guessing.
Hoyt is offline   Reply With Quote
Old 05-28-2018, 05:33 PM   #11
You are right. Figured that out after sending message. A little slow . Thanks
lite, rockwood, ultralite
