Old 04-03-2019, 07:45 PM   #1
Roof weight bearing
Anyone have any info on how much weight the roof on my 2902WS can handle? I am 6-2 245 lbs. Thinking ahead to roof maintenance.
timbob55 is offline   Reply With Quote
Old 04-04-2019, 12:15 AM   #2
There is a You Tube video of the Rockwood assembly line that shows three men on the roof of a unit under construction. I think they just installed the air conditioner as well.
Also, there is a factory installed ladder with no weight limit warnings, that I have seen anyway.
I think you are ok short of a NASCAR style infield roof party.
Gene W is offline   Reply With Quote
Old 04-04-2019, 04:05 PM   #3
Check this short video out
Old 04-04-2019, 04:07 PM   #4
Thanks for the info guys.
Tim
Old 04-04-2019, 04:31 PM   #5
Denver To Yuma In 90 Days
Those factory ladders are junk...don't trust them!
If you try to use them on a regular basis...they will fail.
JohnD10 is offline   Reply With Quote
Old 04-04-2019, 04:50 PM   #6
Mine sags very slightly under my light 150 lbs. I climb it several times each trip to tinker with amateur radio antennas. I do keep the screws snuggled up, which helps a lot.
2011 Sabre Silhouette 260BHS
2017 F-350 XLT CC DRW 6.7L
tinkerreknit is offline   Reply With Quote
Old 04-04-2019, 05:52 PM   #7
It is the plastic mounting tabs that will eventually break...
One of my camping club friends broke his ankle when his failed...
Those ladders are nothing but eye candy.
Old 04-04-2019, 09:37 PM   #8
I am 280 climbed my ladder a few times I admit feels shaky but no problems
2022 Chevy 3500 Diesel SWD
2022 Columbus 329 DVC
moose074 is offline   Reply With Quote
Old 04-05-2019, 02:29 PM   #9
There are three plastic parts, the ends of the ladder rungs, the ends of the standoffs from the trailer body (short pieces of aluminum pipe) and a cover for the steel mounting plate that is round and about 3" in diameter.
The last item might be confused for a mounting bracket but is just a cosmetic cover over a steel plate that is attached to the coach with four screws.
Which of the plastic parts failed in your friends case? I would like to improve mine where possible.
Old 04-05-2019, 09:31 PM   #10
Trailer Park Supervisor
NJKris's Avatar
266 lbs and roof/ladder are rock solid.
Yes, I drink the water!
NJKris is offline   Reply With Quote
Old 04-06-2019, 11:43 AM   #11
And how long have you owned and used your TT and ladder?
Old 04-06-2019, 11:48 AM   #12
I didn't witness the event, but was told it was the two lowest sets of mounts to the back of the RV.
I know several people that have built braces to put under the ladder that fit to the ground.
However, most of them have fixed their ladder troubles with one of these or similar:
Old 04-06-2019, 12:18 PM   #13
NJKris's Avatar
Not long at all John. I plan to scramble up and down that thing as much as possible while it's under warranty, like a fat monkey, lol. See if it has any weaknesses. Great exercise too!
Old 04-06-2019, 12:42 PM   #14
Thanks for the reply.
I'm not surprised that your friend ladder failed at that point. The attachment at the roof is one to check closely as well.
What I noticed in looking at my ladder after reading your previous post was where the mounting plates are screwed to the coach is typical, sloppy, RV screw work when the screws are where they can't be seen. Random angles, stripped heads, inappropriate fasteners. The attachment points can be improved. I need to study the other two areas that I mentioned before to see exactly what is going on there and how it might be improved. The tread attachment points concern me the most.
Carrying a compact ladder is an option to consider but I would prefer the less is more approach if I can make it work.
Thanks again.
roo, roof, weight
