Rookwood 8288ss - Slideout underbelly trim replacement
I have to replace the right and left side slide out underbelly trim (not sure of the actual name but it kinda looks like a ski) on my large slide. The slide extends out about 41" and the piece that broke and needs to be replaced is a black plastic piece that slides on the ABS plastic block on the inside. (see pic of item I purchased from Forest River)
Anyway, I was looking to see if there was anyone who has replaced this item and if so, can you provide me some tips or tricks that would make it go easier. Also, I am going to need to lift and support each side of the slide while installing the ski. Is it ok to just place a 4x4 under the side and jack it up at the floor. Or will this damage something?
Thanks,
Tom G
2013 Rockwood Freedom2381G
2011 Dodge Ram 3500 Laramie 6.7L
B&W Turnover Ball w/Companion Hitch
