Originally Posted by rockfordroo
That switch says it's only rated for 3 amps, so the fridge can't use more than 360 watts at 120VAC.
When you find the power usage one your fridge in watts, divide by 120VAC and you'll know how many amps your switch needs to handle.
The dorm type fridge in my outside kitchen only draws 96 watts. Less than one amp on 120 volt source.
