Old 08-03-2020, 07:58 PM   #1
CampOsborne's Avatar
Safety chain issue
Has anyone had issues with their safety chains rubbing with the stabalizer control bars? I have the Equalizer hitch on our rig and I noticed that the hitch itself is hitting the chain and causing it to almost breaknoff.
Thoughts??
ID:	235574   Click image for larger version
CampOsborne is offline   Reply With Quote
Old 08-03-2020, 08:17 PM   #2
Yikes, that sure doesnít look good. Not familiar with that hitch. Seems itís rubbing on the chains as you turn a hard right or left (wear marks out on the end of the hitch). Have not had that issue with my e2 round bar hitch but Iím sure going to double check after seeing this.
Smart folks on here. Iím sure someone will have an answer for you.
Dirtyspokes is offline   Reply With Quote
Old 08-03-2020, 08:21 PM   #3
Ok. I'm not certain what those pictures show.
One end of the chains disappear and I'm assuming that those are attached to the trailer?
The other end should be attached to the tow vehicle, or am I looking at that backward?
2015 Dynamax REV 24TB class C
Reverse_snowbird is online now   Reply With Quote
Old 08-04-2020, 09:15 PM   #4
What you are seeing is where the safety chain connects at the tongue of my camper. The other end is fastened to the hitch of my vehicle
2005 Chevy Z71 K1500 Suburban
2012 Forest River Grey Wolf 27BH
Old 08-04-2020, 09:16 PM   #5
Def a bunch of smart folks on here. Have read a bunch and solved several problems from this forum.
Old 08-04-2020, 09:50 PM   #6
Could you change to a hitch ball with a longer shank? That would give you more clearance where you are having that interference. I bet 1/2" taller would do it.
And right now, those are the "unsafest" looking safety chains I have ever seen!
-Qwkynuf
2003 F150 Supercab 4x4, tow pkg, 3.55 gears
2020 Flagstaff Micro Lite 21DS
Qwkynuf is offline   Reply With Quote
Old 08-04-2020, 10:16 PM   #7
Take it to a welding shop and have the safety chains moved back so you can still cross the chains.
wildcatter is offline   Reply With Quote
Old 08-04-2020, 10:53 PM   #8
rmac04401's Avatar
I had the same issue with my GreyWolf. I switched from the equalizer hitch to the husky centerline TS. The head is not as big and do not break the chains. I could not even do a 30 degree turn without it breaking chains
2019 Puma XLE 27QBC Toy Hauler
2005 Honda VTX 1300
2012 Ram 2500 Crew cab 6.5 bed
5.7L Hemi, 3:73 Rear
Ron & Shirley (Empty Nesters)
rmac04401 is offline   Reply With Quote
Old 08-04-2020, 11:03 PM   #9
rmac04401's Avatar
Safety chain issue
ID:	235750Click image for larger version
This was the beginning of mine. But mine did look like yours. Click image for larger version
I used these when they were close to breaking in two.
2005 Honda VTX 1300
Old 08-04-2020, 11:26 PM   #10
I'm confused. Do these trailers only have one attachment point for the safety chains? That certainly doesn't seem safe. Ours had two attachment points to distribute the load.
Old 08-05-2020, 12:08 AM   #11
My trailer has both chains attached to a welded ring just in front of the jack. It's a 2020 Flagstaff 21DS.
I have to admit that i chuckled a little when going through the PDI and the tech very earnestly warned me to ensure that the chains were crossed when connecting to my truck.
-Qwkynuf
safety
