Top would be the what your looking for, if you pull the plate you will see how they split it. On the outside make sure your hooked to the right connection
I have done that , so every time now I check to see if I plug into the cable or sat. Connection if your sat is not portable forget what I just posted, make sure you turn that green lite off no matter which model you have
Coachmen M/H
Concord
2018 / 300 DSC
