Should I worry?
Hello all,
This is my first year winterizing our 2504s. I drained the fresh water tank and left the drain valve open, drained, flushed, and by passed the hot water heater. Then with the very valuable help of the DW, I pressurized the city water connection with air while she opened the sink, shower, and tub valves one at a time to get the water out. Then we opened the antifreeze port inside and I hooked up my hose connection and hose to a jug of antifreeze. Turned on the pump, it picked up the pink just fine and ran each faucet til pink came out. Same with toliet and both showers. My unused filter housing sill had water in the bottom half so I depressured the system and pulled off the canister and emptied it. I also poured antifreeze down each drain. The question I have is what about any water that might be left in the line from the fresh water tank to the pump? If it froze wouldn't it just push any expansion into the empty tank? Am I worried for nothing? I thought about putting in 3-4 gallons in the fresh tank but if I did that what would be the point of having a antifreeze port? Thanks in advance for any replies. Jay
