Old 04-12-2017, 11:45 AM   #1
dalemschultz's Avatar
Shower door won't close at the bottom!
We have a 2016 Rockwood 8289WS and the shower door seems to be sticking along the bottom part so that it doesn't seal when in use. Problem! Since we're 4.5 hours away from the dealer and yes it's in warranty, I'd like to see if anyone has reattached or re-aligned their shower door to prevent it from leaking.
Thank you all!
Dale
2016 Rockwood Signature Ultralight 8289WS
2015 Ford F-250 Lariat Super Duty Crew Cab, 4X4, 6.2L V8
dalemschultz is offline   Reply With Quote
Old 04-12-2017, 02:49 PM   #2
WFD
Is yours the single door that is hinged on one side and comes to a stop against a magnetic strip on the other side...or is it the dual doors that slide and meet in the middle. One is bowed in a rounded shape and the other is a regular neo angle shower door.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 04-12-2017, 03:12 PM   #3
Capt. Mike's Avatar
Have you checked to see if the rubber sweep on the bottom of the door may have come out of its track? That happened to us a few times when we had our Rockwood. It might be just a matter of pushing it back into the track.
good luck.
Mike and Yvonne
and Sophie, the little white dog
2017 Columbus 320RSC
2015 Chevy Silverado 2500HD Duramax 4X4
“It's not how old you are, it's how you are old.”Jules Renard
"It's not the years...it's the mileage." - Indiana Jones
Capt. Mike is offline   Reply With Quote
Old 04-12-2017, 03:31 PM   #4
BamaBob's Avatar
X2 what Capt Mike said - same problem same fix when we had our Rockwood. Also make sure there is not a bend in the channel that is preventing the sweep from seating in the channel.
Nights Camped: 2013 - 24 • 2014 - 42 • 2015 - 56 • Jul 2016 - Fulltime •
BamaBob is offline   Reply With Quote
Old 04-12-2017, 03:35 PM   #5
My single shower door did the same thing. The vinyl door seal at the bottom was ripped and hung down just enough to prevent closure of the door. If this is the case, cut the damaged stripping off and it should allow door closure. You may get a minor amount of water leakage. I just placed a bath towel below the door which absorbs the water. Finding a replacement strip is difficult. United RV located in Fort Worth has them and will ship at your expense. The strip will not last long! I just "make-do" with the altered strip on my door and it works fine!
l001952119 is offline   Reply With Quote
Old 04-12-2017, 04:43 PM   #6
bikendan's Avatar
This is what happened with our brand new TracerAir 255.
We took off on a 7 week trip, the day after we picked it up from the dealer.
We hope to have the door realigned and the lower seal replaced.
Equalizer WDH
Old 04-13-2017, 12:05 AM   #7
I raised my door by inserting a couple of C-shaped pieces of plastic under the support that holds the pin on which the door rotates.
Sketch attached.
2011 Traverse LT, 3.6L, FWD
Old 04-13-2017, 01:24 PM   #8
A32Deuce's Avatar
I got replacements from Forrest River Parts. Came in the mail.
A32Deuce is offline   Reply With Quote
Old 04-17-2017, 12:04 AM   #9
Thanks for the replies!
I've replaced the bottom gasket back into the track on the bottom edge of the door only to have it pushed loose again next time someone uses or tries to close the shower door. I think the spacers may work or perhaps I can pull the door and adjust the screws that keep the door aligned onto the jam. I'll work on it. Thank you all.
door, show, shower
