shower drain plug
My shower is draining slowly and I'm pretty sure I have a clog beginning in the P-trap. The drain plug in the shower is the type where you pull up to drain and push down to hold water. It's a little pain in the behind because as you shower if your foot touches it, it closes. A plunger doesn't work real good because as you push down on the plunger you close the drain thereby preventing the plunger from working. I can get a little action on plunging upwards. I don't want to use any chemicals, so the plunger is the way to go.
If I could remove the drain plug, the plunger would easily do the trick, or I could possibly fish the clog out with a wire. Does anyone know how to remove it? By forcibly pulling upward, does it come out?
Thanks in advance.
2014 Ford F250 Lariat
2014 Rockwood Signature Ultra Lite 8280 WS
2023 Forest River Rpod model 201
Louisiana before, fulltiming since April 11, 2014
blog--- www.gozatravels.blogspot.com
