07-03-2020, 05:17 PM
Newbie-big time
Shower miser / diverter
This is from another thread dealing with city water and FW tank; I didn't want to hijack so :
"Also, if your shower has the shower miser (diverter) be sure the valve is turned down. If it is turned up city water will fill your fresh water tank."
posted by Camp4two
Why ?? My wife and I were wondering this anyway after reading the little yellow sticker on the shower controls.
2020 GeoPro 19FD w/off road pack
2022 GMC Sierra 1500 AT4 6.2L
At -600 ft weather and time of day are not a factor.
SSBN624Gold NUC Engineering
07-03-2020, 05:29 PM
If you are using water from your fresh water tank, and trying to conserve water, the shower miser is used to temporarily divert cold water back to the fresh water tank, until hot water appears at the shower faucet. That way you are not wasting water waiting for your shower to get hot. The water is just running in a loop.
If you are on an endless supply of city water, diverting that water to the fresh water tank will just fill up the tank until it overflows.
2020 Sunseeker 2440DS on 2019 Ford E-450, Trekker cap, Topaz paint
07-04-2020, 11:44 AM
posted by Camp4two
So this assumes you are leaving the water running in the shower? If the shower is turned off, the fresh water tank won't continue to fill, correct?
Now, if you are using city water and you are warming up your shower water, the city water diverts to the fresh water vs grey tank. This might be ok as the grey tank is smaller than the fresh water tank.
Am I understanding this right?
07-04-2020, 02:12 PM
Yep, you got it.
The Shower Miser valve only comes into play when the shower is actually on. If the shower water valves are off, the Miser valve is out of the loop.
We have used the Miser valve to fill our fresh tank while at hookups. Turned on the cold water shower valve, placed the Miser valve into the divert position.
Love it, especially when boondocking. We went from using around 90 gallons a week for two of us, to around 70 without even trying. Plus, no more short bursts of cold water
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
07-04-2020, 04:09 PM
An additional benefit is the reduction in wasted water means you're putting less in the gray tank, too.
TV: 2021 Ford F-150 4WD XLT Crew w/ 3.5L EB & HDPP, payload: 2,416#.
Camping nights: 2021, 52; 2022, 99; 2023, 88; 2024, TBD (Est: 80+)
07-04-2020, 04:15 PM
PhD, Common Sense
Is this a device that can be added to any shower in any camper?
07-04-2020, 04:17 PM
Yes! That what we did. Just Google Shower Miser.
07-04-2020, 04:19 PM
PhD, Common Sense
Thanks. In addition to other benefits, using it to fill the FW tank sounds easier than using the gravity fill.
07-04-2020, 04:31 PM
Yes, but it's not cheap and routing the return line can be a challenge. I added a Sink Miser in the kitchen.
Note that, contrary to AquaView's recommendation, Rockwood taps into the fresh water line for the return, rather than returning it to the fresh water tank overflow line. Rockwood's approach can lead to air recirculating in a loop.
When installing my SinkMiser, I revised the installation to conform to AquaView's recommendation, by adding a length of hose back to the tank. Both the ShowerMiser and SinkMiser use it.
07-04-2020, 05:45 PM
Ah Ha!
So that is why when using the Showermiser in our 2205s seems like can not get all the air to purge from the line...
Thanks!
07-04-2020, 05:49 PM
PhD, Common Sense
Thanks. I have started a thread in the r-pod section for model-specific advice. I don’t want to clutter this thread.
07-04-2020, 06:38 PM
Thanks!
Judging from your floor plan, yes. Your bathroom and pantry are in the same location as in our 2507S. I assume the water pump is nearby.
Take out the panel in front of the water pump. You'll see a braided hose coming from behind the shower and T'ed into the fresh water line on the low pressure side of the pump. That's the ShowerMiser return line. Any air in it is recirculated right back into the fresh water source.
To be fair to Rockwood, it is an approved alternate installation method. It saves them some hose and work. It's not ideal, though.
07-05-2020, 06:44 AM
To be fair to Rockwood/Flagstaff plumbing the Miser this way would allow "Winterizing with Pink" to Not be returned to the FWT,where it is a Pain to remove! Youroo!! PS, Not all Floorplans are plumbed the same for the Miser return line!
